Check fuses and breakers
Contact your local service center directly or online here:
Batteries are no good charge them or replace
Do you have 12v when plugged in or on generator? If you do, then it's likely 1) a fuse or breaker for the converter, or 2) the converter is dead. Is your battery good? Try using taking the battery out and using to crank your car or truck. If that works, look at the fuse or breaker for your converter or your converter may be dead. If the batter doesn't work, do the opposite and put your car/truck battery in your RV and see if your 12v works -- if it doesn't, then check your converter fuse/breaker or it may be dead; if it does, then your battery is terminally (pun) dead.
