Question about Mercedes C-Class Exterior Pillar Posts Trim Set
Engine stop while driving. SRS LIM DTR and engine check on the dash board. starts after a few minutes and some times wont start.
Posted by Tamara Tembo on
Phillip Hicks
  • 917 Answers
Bad connection somewhere, need a test unit to check it out for you.
Posted on Jan 06, 2016
Dash board goes dead
1) check and see if your car has a good earthing cable.
20 it could be a loose terminal or fuse.
Mar 15, 2014 | Winnebago 2008 Voyage 32H
Dash board and or cluster going bad
Check your ground strap that goes from the engine to the firewall. It may be loose and moving, causing a disconnect.
Mar 02, 2014 | Nissan Sentra Cars & Trucks
C180 mercedes starts and cuts out
Is engine running on all 4 cylinders when it starts? If it is not it may be the control module on the inner wing under windscreen washer bottle, failure of this module is very common. You should have a scan done to check trouble codes as the control module, is very expensive, good used control modules are available on eBay
Mar 02, 2013 | 2001 Mercedes-Benz C-Class
Where is the idle located on a 1994 Jeep Grand Cherokee limited
It sounds like you do have a relay problem try switching relays around that have the same part number start with the starter relay when switching the make sure the key is off each time
Sep 04, 2012 | 1994 Jeep Grand Cherokee
When driving suddenly the engine cuts out.
I heave the same problem on my Corsa B 1.0 2000, engine cuts out, and whe it happens, I hear one of the relay under the right side of the dash buzzing. After a couple of minutes, starts like nothing happend.
So far I manage to find that the speed sensor is faulty, when I tap him the car stops. I order a brand new one, but I'm not sure that was the issue.
I order also a Opel Tech2 tester from ebay and it has to arrive next week, then I can see the error code.
Jul 13, 2012 | Opel Cars & Trucks
Wont start but if you let it sit for a few minutes with key on then it will start its like the fuel pump is not getting power until it warms up
Your ecu is going bad and in need of repair since it will not send power to the fuel pump relay until the check engine light illuminates on the dash board. It might take only a few minutes now but it will probably take longer as it gets worse. Check to see if it is the check engine light no coming on for a few minutes, on your jeep, and then you will know for sure that's your problem.
Jan 23, 2011 | 1994 Jeep Grand Cherokee
WHEN YOU PUT THE CAR IN DRIVE IT WILL NOT GO ANYWHERE
Its the electronic shift control located just under the battery ontop the transmission replace or repair will solve the issue
it'll go into drive but once it reaches 1500 rpm it'll drop into neutral as a safety because at this rpm it is being told to shift gear and when it fails to do so it safely goes into neutral
it will go into reverse just fine and park and you can run all the low drive gears until you reach 1500 rpm then it'll cut it off
i pulled mine out re soldered bad components on the board to fix it but im an electronics engineer it may be easier for you to just replace it
Aug 09, 2009 | 1995 Dodge Avenger
SAME
back box behind the ign switch is a common thing that gos giveing a mixture or problems to do with lights on dash even starting
Jun 10, 2009 | 1996 Saab 9000
Srs , battery lights, abs lights car stopped
Have the battery load tested to verify if it is good or bad.After the battery test,remove the alternator and have it tested for proper output.Places like Auto Zone will test both for free,but you have to remove from the car,and take the items to the store.
Oct 26, 2008 | 1997 Mitsubishi Diamante
Mercedes C-Class Exterior Pillar Posts Trim Set Logo
160 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Bill Boyd
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
