Health & Beauty Logo
Judith Goff Posted on Nov 08, 2015
What does the code +- mean showing up on left side of 2006 model salter kitchen scale
4 Related Answers
Anonymous
  • Posted on Aug 18, 2009
SOURCE: Can't open battery case
The middle part slides out. You'll need a small knife or a screwdriver to pry it out gently.
There are openings on two sides. One side has a larger opening than the other. Make sure you pry it out of the lager opening.
Once you gently slide it out, you'll see the two batteries. Make sure the positive side is facing up when you put them back in.
Hope that helps!
awa13
AWA
  • 78 Answers
  • Posted on Mar 21, 2010
SOURCE: Salter kitchen Scales Model: 1041SVDR won't turn on.
This sounds very typical of kitchen and postal scales. I know you don't want to hear this, but this basically means it is time to replace your scale with a better scale - perhaps no longer giving Salter your business..
Anonymous
  • Posted on May 23, 2010
SOURCE: setting the clock on salter scale model 5007
Hold down the g-oz key and the off key at the same time for about 5 sec's
The hour digit will flash
press the ml-floz key to move the hours.
then press the g-oz key again to move to the minutes.
press the ml-floz key again to set the minutes.
press the g-oz key and it moves to setting the cloak to 12h or 24h option.press the g-oz key to set the time.
And your done.
LaidlawUk
  • Posted on Jun 28, 2010
SOURCE: Kitchen scale, Salter, model 2006: change batteries
The 1 part just slides off.
2006 salter scale manual
This is a very basic 2 button scale.
https://www.google.com/search?q=salter+scale+manual
Strangely, the manual is not showing up.
https://www.google.com/search?q=salter+2006+Microtronic+manual
Very easy to use. Left button is imperial or metric. Right button is on and off and tare. Batteries for in a compartment underneath.
What else do you need to know.
2answers
How do i get battery compartment open on Salter kitchen scale model 2006
I went to the Salter website and I could not find that model number.
Salter Disc Electronic Digital Kitchen Scales White
However, looking at the other models they had there should be a door on the bottom of the scale. It looks like a release tab that you push in then lift up on. Give that a try.
1helpful
My Salter model 3003 kitchen scale shows Err when I turn it on. How can I fix this?
This means that it cannot calibrate itself because the sensor is out of range. This can happen if you drop it or overload it. Check the feet on each of the for corners and make sure they are not stuck, you can do this with the unit on and see if it registers any force on the pads when you press and release them or use a screw driver to lift them SLIGHTLY. There are a lot of youtube videos on how to check and repair them.
My Salter Model 2001 kitchen scale, shows an 'ee' on the screen. This error code is not listed in the manual. Any suggestions?
"EE" means that the scale has been overloaded. Try placing a small weight (i.e. 250g block of butter) on the scale and then turning the scale off and then on again with the small weight still on the scale. What this does is to try and re-calibrate the scale. If this doesn't work then I am pretty certain that the scales will need to be replaced. The scales in question do have a 15 year guarantee and you can try contacting Salter Housewares directly if you have your proof of purchase.
https://www.pricescompare.co.uk/q&a/ee-showing-on-screen.html
2answers
I have a Salton 2006. When I replaced the battery and pushed the on button a small icon with + and - above and below it flashed in the upper left corner. What does this mean?
Can you please confirm if this is the product you are refering too?
https://www.pricescompare.co.uk/kitchen-scales/product/salter-aquatronic-platform-scales.html
2answers
Battery code for Salter kitchen scale Model 6055
i needs manuals of calibration of the scale salter model 6055
5helpful
3answers
7helpful
2answers
E appears on Salter scale, even with new batteries
Hallo I have problem witch kitchen scale Salter.E appear when I pushed on and it takes 3 sec
How can I fix this problem
Than You
Top Salter Health & Beauty Experts
vince
jws1013
Ngoro
Are you a Salter Health and Beauty Expert? Answer questions, earn points and help others
