Gas line is clogged if your pilot lite goes out - They got rid of pilot stoves because the pilot was always lit and using gas.
And without a lit pilot no way you can get the burner to ignite unless you use a match, assuming you have gas going to the burner!
I took off the pilot light tube and cleaned it. Do you think maybe the thermocoupler is bad not allowing the gas valve to function properly?
"Once the oven safety valve's thermocouple senses appropriate heat, the safety valve opens to allow gas flow to the oven burner where the pilot flame ignites the gas." There is your answer.
