Question about Motorola Radio Communications
I have two Motorola MJ270R and one doesn't work. The LED Indicator lights up and stays on continous, however nothing happens when I turn the radio on. I get no volume nor a display screen. Please help
Posted by Michael Culbertson on
eradiostore
  • Motorola Master
  • 1,658 Answers
Trade batteries with a known good unit and see if it solves the problem. If not, your radio has an internal problem and needs replaced. Here's a link to the user guide page.
Product Manuals
Posted on Apr 12, 2016
5 Related Answers
eradiostore
eradiostore
  • 1658 Answers
SOURCE: Motorola T5950 led screen
Typically a blank screen indicates you are using a bad or defective battery. Try the battery of another radio in this unit and see if the problem still exists. There is no function to shut off the display screen, so it is apparent you have either a battery or radio problem. Here is a copy of the user manual: http://www.giantintl.com/ContentManage/manuals/Moto/T59xx_User_Manual_E.pdf
Posted on Apr 08, 2009
eradiostore
eradiostore
  • 1658 Answers
SOURCE: Radio will not transmit, display seems wrong
Here is a link to the user manual for the SV600R. http://www.giantintl.com/ContentManage/manuals/Moto/SX600%2012-21-07.pdf Follow the instructions to reprogram the affected radio. Note: The problem you are describing may not be simply programming. The radio problem may be non-reversible. You might also try a new battery, or switch the battery from the other unit for a test, just to see if the battery is bad.
Posted on Jun 08, 2009
eradiostore
eradiostore
  • 1658 Answers
SOURCE: I have a Motorola SX600R two-way radio. Battery
Remove the battery and reinsert it to reset the radio. Also, check to see if any buttons are depressed or stuck. If these are not the cause, you might have a bad radio. (Sorry)
Posted on Jun 10, 2009
Anonymous
  • 3 Answers
SOURCE: Can't change channel of a Motorola Visar
The Visar has a channel lock feature. If you hold down the two channel buttons at the same time, it will do one of two things depending on the settings. Either the channel will lock, or the channel numbers in the LCD will flip.
If you press the channel button and the "popples" "pop" (for lack of a better word) then the channel selection buttons re most likely OK. To fix it you just press both channel buttons at the same time for about 5 seconds. It will beep and you should be able to change the channels. If not, then it needs to be repaired.
Posted on Mar 29, 2010
Peter Philips
  • 607 Answers
SOURCE: Ok i baought 2 Motorola MJ270R walkie talkies, Then i found 1 more with no charger or anything at my moms house, And there all the exact same walkie talkies there all MJ270R Walkie talkies, And was w
Hello Ty,
Tis a problem you have there, however I would advise you take one of your radios to radioshack or similar store, and the folk there should be able to assist in finding the apropriate chargers for you.
I hope this helps you in your quest.
Cheers,
Peter
Posted on Mar 10, 2013
One handset is not responding and when pressed for long time the emergency alarm is turned on. Is there any reset button to troubleshoot this...?
remove battery for a few minutes and see if connections are clean- if when batteries are inserted and still have problem--- problem with mother
Jul 10, 2016 | Motorola MJ270R Two Way Radio
NEED MANUEL FOR MJ270R TWO WAY RADIO
Cootact Motorola Solutions. Http://www.motorolasolutions.com/support
Mark
Motorola Mobility Support
Sep 23, 2014 | Motorola Radio Communications
Remote for ceiling fan light stays on
Sounds like you need a new transmitter. The light is a battery indicator light.
Mar 06, 2014 | Savoy House Dryers
HEllo, I have a Motorola Radius CP200. When I
If the sound is continuous, like a long tone humming, it is possible you are on a channel which is not programmed. Try changing your channel knob to a different channel and see if the sound changes.
If the sound is not continous, and only happens upon pressing a button, we are not certain what you are experiencing without seeing the radio first hand.
If it were the battery you would get a low battery beep and then the radio would shut itself down. This can happen from a bad battery or a low battery. If this were the situation, you should check your charger and be certain the light comes on and stays on when the radio is placed on the charger. (Note: your radio should always be turned off when on the charger.) A quick test would be to swap the battery with a known good radio and see if you have the same problem. If so, you know it is not a battery or charging problem.
If none of these items help, send or bring the radio to a Motorola repair shop for a quick analysis.
Best regards.
Aug 21, 2013 | Motorola CP200 Two Way Radio
Hello Ty,
Cheers,
Peter
Mar 08, 2013 | Motorola Walkie Talkie 2-Way Radio
MJ270R
Typically this would indicate a battery problem. Try swapping batteries with a known good unit. If the radio still shuts off when the PTT is pressed you have a radio problem. If it works fine, then you know your battery, despite showing fully charged, is bad.
Best regards.
Oct 24, 2012 | Motorola MJ270R Talkabout 2-Way Radios...
I have a Motorola MR350 and have been using the pair for several months now. I must say, the coverage is pretty good and I really enjoy the design. However, last night when I turned it on, the user on...
It is possible you have one rechargeable battery pack getting weak. Try swapping the batteries, and see if the problem leaves, or changes to the other radio. Typically when batteries start to go bad a common sign is hiss, static, no transmit, or intermittent transmit.
If you do find it is a battery problem, then check your chargers. You could have one charger causing the problem, or simply dust/debris on the charge contacts. This can happen from hand oils getting on the contacts, and then over time dust accumulates and creates a barrier between the charger and the radio. These can be cleaned with a pencil eraser.
Always be certain the radios are turned off when on the charger.
If the battery and/or charging set up is not the problem, then you have a radio problem. If it is the radio, you will likely need to replace it. Parts and schematics are not available for this model.
Best regards.
Sep 24, 2012 | Motorola Radio Communications
Motorola talkabout MJ270R switching off when transmitting
Turning off while transmitting is typically a sign of a weak or bad battery. However, since you mention it happens with either battery type, another cause might be the length of time you are depressing the PTT button. These radios have a fail-safe to prevent damaging the final amplifier of the radio. To protect itself the radio will shut down or stop transmitting after the PTT button is held in too long. This being said, I'd check the batteries first. The rechargeable battery pack which came with the radio has a one year life expectancy. A battery can test full when it is weak and might not hold the charge when placed under a load. And usually transmit is the first thing to fail.
Best regards.
Jan 24, 2012 | Motorola MJ270R Two Way Radio
Radio Communications Logo
348 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Ekse
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
