SOURCE: Coffe groungs drawer full of water
when you make ourself a expresso do you have the same amounth of coffee or it mush lower if recently you clean the machine inside check if you screw or put back everything at there right place let me know thanks for using fixya pierre
SOURCE: Replacement Part
Check one of the followinfg sellers :
Home Page Seaco,Gaggia,Spidem,UNIC,LaPavoni Espresso machines, parts
Gaggia Espresso Machine Parts
or see here GAGGIA Replacement Parts
You usually need to call the seller to get the price and order the part.
SOURCE: Gaggia Classic Cannot insert coffee
You will have to reseat or replace the head gasket.
Testimonial: "thank you will look into it"
SOURCE: I have a Gaggia Syncrony
Caution:The coffee grounds drawer must only be emptied when the appliance is
ON. The drawer must be removed for at least 5 seconds. If the drawer is emptied with
the appliance OFF, coffee will not be dispensed when the machine is switched back ON.
This is quoted from the manual. Have you emptied it while ON?
SOURCE: Gaggia brera, coffee beans compartment is full of
I have the same problem. Not a solution, but you can still take the ground beans and brew coffee, using the pre-ground compartment.
