Computers & Internet Logo
A
Anonymous Posted on Nov 07, 2015
Laptop not recognizing device when plugged into laptop how to fix
When I plug in my note 3 to my laptop it says unrecognized device.i have tried all I know and nothing fixes it. what to do
James Wassinger
Level 2:
Habit-Forming:
Scholar:
  • Expert 71 Answers
  • Posted on Nov 07, 2015
James Wassinger
Expert
Level 2:
Habit-Forming:
Scholar:
Answers
71
Questions
0
Helped
13501
Points
251
The computer is not recognizing the device because the appropriate software or driver is not installed on the device.
Most of the time when you connect a smartphone into a compatible laptop the device drivers or software automatically install, so the laptop may recognize the smartphone.
Here are some possibilities as to why the device is not recognized.
1) The USB port is bad.
2) The USB port is not activated
3) One of the devices does not support the other
Here are a few possible troubleshooting solutions:
1) Go to the smartphone manufactures website and download and install the updated device driver and software then plug in the device to see if it is recognized.
2) (if Windows OS) Go to the Device Manager to see if the device is showing up when it's plugged in. If you see the device in device manager right click the device and choose to update the driver.
3) (if Windows OS) Additionally, in device manager you can check your device's USB ports to see if there is an issue with the ports that may be resulting in the smartphone not being recognized. You can choose to re-enable the USB ports or update the software for the USB ports.
Hopes that helps resolve your issues.
Open Device Manager Windows Help
I’m happy to help further over the phone at https://www.6ya.com/expert/james_d4449ffdf318a2c3
1helpful
Why my pc shows your device is unrecognized when i connect my pendrive to pc
it may be due to malfunctioning of your USB port, just try to plug out and then plug it into another Port
Windows 7 does not recognize my camcorder when plugged in via usb Unidentified Device - no driver found
it recognize it as a storage device. when its plugged in if it shows an external device or unrecognized device found you have to download the software to connect it . try to download it via www.piratesbay.com as there are more software's . make sure you type your model no when searching to download
May 13, 2011 • Cameras
I have a diamond mp3 hooked up to me laptop but windows media does not detect it. What do I need?
Unrecognized devices often mean hat the drivers are not installed or available in Window. Try installing them if you have a CD.
There are more possible problems with unrecognized USB devices, so I suggest you have a look here if the drivers don't solve the issue.
http://www.pcauthorities.com/drivers/usb-device-not-recognized
Unrecognized
some proble was in USB socket of your external HDD...poor contact...
try to use another HDD enclosure to use with you HDD..
that problem occur due to pluging in and out several times...maybe the connector was damaged...hope it helps..
or try another PC again...some problems are not detected due to virus in PC...
I just purchased a new Laptop. I have stored all
Restore your laptop back to yesterday - when it worked. Once you're done with that, try your external again. It should now work.
Hope this helped you. Good Luck!
After Seagate device not recognized, all flash drives gave troubl
even tho you have AV software installed , I wouldn't write it off so easily. Download and run Malwarebytes from
www.malwarebytes.org
and you may be surprised how ineffective AV software can be some times.
Don't forget to rate the advice!
http://www.aa1consulting.com
EXT HD UNRECOGNIZED BY LAPTOP
Which operating system are you using? Windows XP or Vista?
Here is the website that you can download the driver for your external harddrive.
http://support.wdc.com/product/download.asp?modelno=WD1600JB-00FUA0+WD+&x=1&y=11
9helpful
4answers
Sg4 problem
This may sound crazy but I had the cable connected incorrectly (I was getting a message that my Sky Caddie SG4 was unrecognized). When connected the cable correctly (to the back of the SG4) the cable wire should be pointing down.
Thats all it took to fix this issue for me.
HID malfunction
Link... check out the input device drivers and the chipset drivers.
update these and unplug and plug back in.
JVC-Digital Video Camera
If it is a JVC digital camera (DVC or hard drive) you need to have the camera set to the "Play" mode, and turned on before plugging in the camera. Vista should recognize it as a digital source afterwards. You need to have a firewire or USB cable for the camera, and the port it plugs into needs to be recognized. Be sure you don't have an unrecognized device in /Control Panels/Device Manager/
Hope this helps. [email protected]
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
