SOURCE: xerox 390 error code 1
> Support & Drivers > WorkCentre 390 Laser All-in-One Support > Search Results > How To Clear a Fuser Error Message
Solution: Perform a RAM Clear
Make Printable
Email this page
Performing a RAM Clear will restore all of the WorkCentre's
settings to the factory defaults. It will also clear all faxes in
memory, Speed Dials, One-Touch Buttons, Group Speed Dials, your System
ID, and any other stored information.
NOTE: If you are able to print, it is a good idea to print
out your Phone Book before performing the RAM Clear, to assist you in
reprogramming your Speed Dials and One-Touch Buttons. It is also
recommended to print out your System Data List to assist you in
reprogramming your system settings. If you are not sure how to print
your Phone Book or System Data List, refer to Related Items at the
bottom of this page.
To perform a RAM Clear:
SOURCE: xerox printer error code (04,025.46)
This is a print head position issue.
TRY FIRST (Solutions without parts):
1. Check that the wipe mechanism has homed. 2. Check the printhead position and verify that it has initialized properly / manually home the printhead and power cycle the printers power and check for the error to return. If not then the error was most likely due to non-process function (something out of sequence).
Part likely to be the cause:
GEARBOX AND MOTOR,PROCESS DRIVE - PL 4.0, Item 14.
SOURCE: Xerox Phaser 8500N Printer Error 09,037.45:9085
Hi Signrite: This should help out. It looks like you are having a problem with yellow.If you are using a third party ink (non Xerox) then you may be having a printhead.
9,035.4x through 9, 038: Fault codes associated when ink count flags are stuck
after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41, where x= 5
for cyan, 6 for magenta, 7 for yellow, and 8 for black.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 1. Are the ink sticks all Xerox ink? Go to
Step 2.
Advise
customer. Run
clearISCfault
test to clear the
error.
2 1. Manually verify that the ink stick is able to
advance in the ink loader chute.
Go to
Step 3.
Remove any
blockage and/
or replace the
ink stick.Run
clearISCfault
test to clear the
error.
3 1. Run the appropriate Ink Melt [1, 2, 3, 4]
Heater test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
2. Did the test pass?
Replace
the
printhead.
Replace the ink
loader
assembly. Run
clearISCfault
test to clear the
error
SOURCE: Can Xerox Phaser 6280 be refilled by Consumers?
The 6280 uses a specially designed toner called Emulsion Aggregation toner. This is a special type of toner made by Xerox. Sice it is so new and patents exist, I doubt that anyone can legally make the toner, even if they posessed the equipment and the expertis. Refilling with non-EA toner is asking for big trouble.
