James Carr Posted on Nov 07, 2015
Best way to hook up Bose 901 series VI to a Harman Kardon HK3490
geekyshrink
Level 1:
  • Contributor 43 Answers
  • Posted on Dec 02, 2015
geekyshrink
Contributor
Level 1:
Answers
43
Questions
0
Helped
20875
Points
63
According to the HK site, "Stereo pre-amp outputs let you connect the receiver to an external power amplifier." So it's easy. Connect the Bose equalizer in the pre-out / amp in loop.
1 Related Answer
Anonymous
  • 8546 Answers
  • Posted on Feb 04, 2011
SOURCE: I have harman kardon AVR
I have a setup similar to what I think you're trying to do and it works great!
You're in luck because you have a full complement of pre-outs. You'll need a separate amp for the 901's.
First some background.
The use of 901's Active EQ (or any external proxcessor) in any digital AV receiver setup for anything EXCEPT STEREO listening through the 901's alone requires you to have a separate amplifier for them and to avoid having to use a Tape Monitor which could introduce proprietary and potentially damaging Active Equalization back into anything in the AV Receiver with its conventional speakers.
In an AVR, if you activate any Tape Monitor circuit at all, you will kill any digital sources. That is a function of AV receivers in general, nothing to do with 901's. Your Pre-Outs get us around that possibility and limitation but it also means you need a moderately powerful amp for your 901's. I use a Carver MT-200.
Run it with the Active EQ between the receiver Front L and R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out (or one of your analog Tape Outs) >>> Bose EQ Amplifer IN, then Bose EQ Amplier OUT >>> new amplifier IN.
The AV Receiver can still drive the Center, Surrounds and the Sub(s) as it is designed. This is how mine is wired.
Then set the new amp's volume control (if it has one, mine doesn't) to something HIGH and leave it alone. Run through your speaker setup routines on the AVR. After levels and distances are set the AVR will be the boss of the 901's. With 901's don't even need subwoofers but they don't hurt. If you do have subs I recommend sharing the LFE with the 901's.
I've done this in my own setup once. Turn the 901's around so the rear faces point into the listening area. Crank up a movie like Master and Commander and when the waves are crashing or cannon are firing you WILL FEEL A BREEZE from them. Now THAT is multi-media! I advise having the 901's share LFE with any subwoofers you might have.
http://www.retrevo.com/support/Harman-Kardon-AVR-230-Receivers-manual/id/386bh145/t/2/
How to hook up my bose 901 to h&k 1710s
The Harman Kardon AVR 1710S is a 7.2 channel 700watts amplifier.You can connect the Bose 901 speakers to the front speaker connections at the rear of the amplifier for maximum performance
2answers
Recently I bought a Harman Kardon HK 3770 Stereo receiver. My question is " can I use a Bose 901 Series VI speaker with this receiver?, since I plan to buy a 901 S VI speaker.. The receiver has no tape...
From the description of the Harmon Kardon, it sounds like you should be able to use the speakers, but you will not be able to use the active equalizer. The equalizer is designed to be cabled into the tape monitoring loop and allows you to listen to the equalized signal coming back into the receiver. Attach the +/- speaker wires to the right and left channel speaker connectors on your receiver.
Harmon kardon avr 146 with Bose 901 EQ VI
Bose is a pain in the back like Apple. Everything they make is proprietary or it won\'t work. The 901 series is one of them.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/ernie_b93ee48ba0eab50b
How do you hook up the Bose 901 series VI to a Harman Kardon AVR 510 receiver?
Search Fixya for the dozens of times I have answered this type of question. The central theme is you will need a separate power amp for the 901's and use of the Pre-Outs.
http://audio.manualsonline.com/manuals/mfg/harmonkardan/avr_510.html
Not sure of how to wire these speakers ( internal ) Bose 901 series iv
Found on Google Search: "bose 901 internal wiring" You must first identify which series you have. The first two series were acoustic suspension, and used nine 8 ohm drivers in a series/paralel configuration. Series III through VI used nine .9 ohm drivers all wired in series. Series III and IV had an additional terminal for use only with the Bose Spacial Control Receiver. Series III through VI are easy to identify, as there are three ports sticking out the back of each enclose. The 1st two series have no ports.
How can i hook up my 30gb Ipod to my Bose 901 series VI and i have it hooked uo t couple of yahamhas
There has to be some amplification in here somewhere. Any single amplifier will not work correctly with the Active EQ for 901's applied to non-901 speakers.
Any MP3-player device with at least a headphone output can feed any standard audio device that has a Line Level input (other than "PHONO") once the output is adapted to fit the input.
2answers
Bose 901 equalizer hookup
how do I hook up the bose 901 EQ to a yamaha DSP3090??
1helpful
2answers
BOSE 901 ACTIVE EQUALIZER
i, trying to hook up a powered subwoofer to my hafler dh 110 and dh 500 running a bose 901 series v active equalizer and series v 901s any info would be appreciated
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
