You may have to get a screen replacement. You can do this yourself if you want to try it and buy the parts. Or take it into a shop, or apple will replace it but most likely charge you way more than any of those options unless its your first replacement.
If you won't see anything on screen,check if the phone is booting or turning on,if it turns on,display is probably the problem.but if doesn't power?software problem is the main cause.and with this,need to replace LCD as well as touch screen that was damage too.
If your mobile has a warranty,you can bring it to the service center for spare parts replacement.If you try to open it and it's under warranty,this will void you warranty and unable to benefit free of service charge.
Did it get wet? If it did turn the phone off, take out the battery and SIM card and place it in a bowl of uncooked rice..this will soak up the moisture.. leave it in there overnight and then put it back together and turn it on.
Sometimes the touchscreen fixes itself..
The last solution i have it to use a lighter to LIGHTLY wave over the screen...add pressure to the screen.. and then try it.
