viewsonic va1703w screen is starting blur and it is changing colors Screen goes black or pixelates and after 15 to 20 mins by pressing the power on button of the monitor it is getting switched on, and again when restarted it is having the same problem.
1.Locate the problem pixel. Display a true black image on your HP's monitor. You can do this by playing a DVD on your HP laptop, and pausing it on the black screen just before the movie starts. Once you bring up a black image on screen, the stuck or dead pixel should be visible.
2.Try applying direct pressure to the problematic pixel. After you've located it, turn off your laptop. Place a soft cloth or rag over the pixel to avoid damaging your screen. A soft chamois works well. Using the tip of a pen, apply gentle pressure to the pixel. You don't need to press hard, as too much pressure can crack or scratch your screen. While applying pressure, boot up your laptop. This should force the pixel to begin working properly.
3.Tap the pixel. With your Toshiba booted up and an image on the screen, gently tap the pixel with the rounded end of a pen cap. Tap hard just hard enough to see a small white flash on the screen. Tap your HP's screen until the pixel begins working properly.
4.Download a stuck pixel program. Several programs, including JScreenFix, UDPix and Pixel Protector, are available for download and can help fix a malfunctioning pixel. These programs display rapidly changing colors and images on your screen. The flashing colors and images can force the pixel to begin functioning properly.
5.Contact HP. If none of the above methods work, your screen may have a pixel that is truly dead. If that's the case, the only option is to replace the display completely. Contact HP customer support at www.hp.com to find an authorized repair service near you.
1. Delete/uninstall all facebook apps. 2.
Clear stock browser (not dolphin) and point at touch.facebook.com.
Touch "places" and blindly accept all popups and dialogs. Play around
and make sure places works. 3. Bookmark touch.facebook.com and on the main screen, add that bookmark. It's not a pretty icon, but it works!
Good luck. If you have a better way to do this, I'm all ears.
Hi my name is Roety,
I can help you with your issue ,
LCD TVs are built with a panel (screen) and usually two boards a power supply and main board.
What you discribe can only be caused by a bad panel?
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
The problem with this is it's not just glass -Liquid Crystal Display- it's a matrix of liquid crystal cells, the screen also has like individual pixel color filters as well all this placed between two sheets of polaroid coated glass. It isn;t just so easy as to replace it like a regulare tv screen. As with anything it could be repaired, I have read about, but cannot suggest anyone particular place because the repair involves putting material into the cracks then laser etching the grid back in. So if you can find someone who does that. Or ask you dealer about it. Sorry I could not give you a better solution.
Blurness doesn't happens because of the number of the pixels in the cameras. Is the picture on the computer screen blur/the cameras screen or the lens hole?
I suggest you to set the camera on Automatic station (red camera on the wheel) in day light,try to stay still see how blur the photos are when you are not playing with the parameters. it it's still blurry it could be the pulley block next to the -eyepiece. roll it until it's not blur.
