Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
36" trinitron no picture, stanby lights blink 4 times. Is my only solution to take it to a repair shop?Thanks, Jeremy
Posted by Airjer on
  • Anonymous Nov 30, 2007
    my sony tri tv blink on and off and check everything inside no solution, smack the tv 4 or 5 time if the problem will go away nothing.
Anonymous
  • 28 Answers
Yes, problem is not a diy type, sorry.
Capital98
Posted on Nov 23, 2007
Sony trinitron 36" has 7 red blinks wont turn on
I HAVE A SONY TRINITRON KV-36HS510. IM HAVING A PROBLEM,ITS NOT SHOWING A PIC, AND BLINKING 7 TIMES THEN PAUSE FOR A COUPLE OF SECONDS THEN IT WILL BLINK 7 MORE TIMES,I CAN HEAR AUDIO BUT CANNOT SEE PIC. COULD YOU PLEASE HELP ME OUT ,I'VE TRIED CUTTING THE TV OFF FOR ABOUT 6 HOURS AND CUTTING IT BACK ON,SAME RESULTS, THANKS
Jan 02, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
My Sony Trinitron shut down last night. I
4 times standby light blink shows that tv got problem in vertical deflection section and probably vertical output IC got defective, need to be replaced.
Replacement of parts in circuit board requires soldering work and expertise so call local tv repair shop guy if you are not familiar with soldering work.
Thanks.
Jul 25, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
My sony trinitron turns off by itself and then the stand by light blinks five times then pauses for like 4 seconds then flashes 5 times and repeats
This is picture tube related problem and we call it incorrect white balance.
Adjust Screen Volts of picture tube and control knob wold be located on flyback transformer. If you have knowledge about tv and know that tv contains high voltage and you can take care of that then do it yourself or ask local tv repairman to fix it.
Thanks.
Jun 12, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Blinking/standby timer
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
Jul 01, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony trinitron kv-36fv26 (2000) tv wont show picture
Trires unplug,replug about an hour later see if it reset it self.Not take to the shop the two power ICs help the power it dead.Need it replaced.
Jan 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Sony FD Trinitron Vega 2004 Stanby Flashes TV will not turn on
This unit shouldb e flashing a repeated count on the standby light. That count will indicate the circuit in which a problem was detected causig the shutdown. Please post that count and we should be able to provide details on the repair.
Thanks,
Dan
Jul 07, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony Tv Problem
The 4 blinks indicate the problem circuit, but I need the model number to give you the specifics. The category you entered is KV-36fs120 which is a 36 inch set. Please update this with the model number. It should be on the back.
Thanks,
Dan
Apr 03, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
1999 Sony Trinitron TV. We have sound but no picture. Stanby light is flashing?
How many times does the light blink. It should blink a code 1-8 blinks pause a second then blink the code again. Count the blinks then let me know. If it just blinks constantly without pausing. let me know that as well.
Jan 19, 2008 | Televison & Video
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
73 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
