Radio Communications Logo
Mary Owens Posted on Nov 04, 2015
Will the Jabra Style+ headset announce caller? Or is this a function of the phone itself?
5 Related Answers
Anonymous
  • 52 Answers
  • Posted on Feb 11, 2008
SOURCE: pairing Jabra BT135 with motorola L2
okay, try this, turn off the jabra headset, and then, hold the power button but hold it down until the lights flash in a different way, and make ur phone search for devices and if it finds it then its all good, just use the 0000 password to pair it.if this works give me a fix rate. thank U
Anonymous
  • Posted on Aug 23, 2008
SOURCE: Cannot pair a7010 with Plantronics Voyager 520
The actual problem was Plantronics, I was not turning on pairing mode. I was confused with quick pair which starts not immediately after turning on, but you need to hold the button longer until led will start blinking blue and red.
Anonymous
  • Posted on Jan 28, 2009
SOURCE: unable to connect jabra t5330 to a cisco ip phone 7941G headset jack
You can solve this by connecting your phone inline.
On the back of the phone where the phone handset plugs into, plug one end of the jabra headset wire & connect other end to the 2nd position (marked by phone & handset). Now plug the handset wire from Ip phone to the 1st position (marked by handset) in the jabra headset. Now you are good to go.
When the phone rings lift the phone handset and answer it with your jabra headset. You can't use jabra with 7941 without lifting the handset on phone.
Anonymous
  • 4 Answers
  • Posted on Dec 16, 2009
SOURCE: Jabra BT2050 Bluetooth Headset not found on cell
Try pairing it again. Make sure Bluetooth is enabled on phone, turn the BT2050 on by pressing and holding the side power button. Then, press and hold the center (round) button for at least 10 seconds (light will stay solid and it is now on pairing mode). Follow instructions on your phone. Hope this helps.
Testimonial: "It worked! thanks a lot =P"
Anonymous
  • 4 Answers
SOURCE: my jabra headset won't pair with my phone--my
Assuming you're talking about the Jabra BT2050 headset press and hold the center (round) button for at least 10 seconds; light will stay solid entering the pairing mode. Follow instructions on your phone.
Testimonial: "This worked perfectly! Thanks!"
GALAXY 21 mobile paired to Jabra Tour 5G headset
Delete Jabra from Phone and reboot. Tell phone to search for Bluetooth devices. PRESS THE BLUTOOTH BUTTON ON JABRA! Now you are Paired. Make sure phone is not on Mute.
Jabra Tour - Support
https://www.jabra.ca > Support > Jabra Tour
Get support for your Jabra Tour. Find all product guides, resources and FAQs.
I forgot how to get my Jabra tell me from my contacts names instead of the phone just ringing in my ear.
?? your contacts list isn't stored in your earpiece , its stored in your phone that the earpiece connects via Bluetooth too , so if your "phone" doesn't verbally announce whos calling to you then I don't see how your ear piece is going to ??
I have no codes in my manual which came with my Jabra Style. Have even downloaded the pdf manual, still no codes. Can you tell me how I can use this app please?
Usually the Jabra headset connects via blue tooth. You pair it with a smart phone once. No codes other than the pairing number you see on the phone when starting the pairing process.
Won't announce caller just rings
This will be on your car's bt set up.
9helpful
4answers
Resetting my jabra extreme 2
If your Jabra Extreme2 Voice guidance is not turned on - i.e. you only hear beeps when you power on or a call comes in...
Cause: powered on or off with answer button depressed
Solution:
1) Power off
2) Hold down answer button (the one that lights up Jabra)
3) Power on
4) Release answer button
You may need to repeat.
1helpful
2answers
I just got this bt8010 have no idea how it works
You have to install the Jabra Control Center, and it will take you through the steps.
My Jabra BT500 is on mute. Callers can not hear me. It worked fine at first now nothing.
When powered up and in "talk" mode (during a call) hold the volume up and down "bumps" simultaneously. This engages/disengages the headset's mute function.... Hope this helps...
4answers
English instruction manual
you need to charge the head-set fully and then.... disconect it from power supply. hold down the call button until a continus light appears. and then flip out the speaker tusk.... then search for the device on your phone a couple of times.... if you dont find your headset then your phone is not compatible with the head-set....
No sound
Had the same problem with the BT250v 'connected' to my Nokia 6021. When connected to my notebook, the 250 did produce sound, so decided the Nokia was the problem. Fixed the problem by doing a full reboot of the phone like this:
Jabra: Turn off the 250
Phone: Delete the BT connection to the Jabra (in BT settings)
Phone: Switch off BT
Phone: Turned off the phone (I've even removed the battery)
Phone: Turned on the phone
Phone: Switch on BT
Jabra: Turn on the 250 for detection
Phone: Look for audio devices
Phone: Connect to Jabra
Problem fixed!
Top Jabra Radio Communications Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
