Question about Doro Phone Easy
Got unlock code and when I replace with new sim from new network, the phone displays sim error message. Is there anyway to get round this to enter the unlock code?
Posted by Marshall O on
1 Related Answer
marrymemarif
Andy Lee
  • 17 Answers
SOURCE: unlock code for Doro PhoneEasy 615 ?
Oper.Code, is the operators code, not an unlock code. The code that the operator you got the sim from, should give you. It could be on the credit card sized frame you broke the sim out of or in the packaging.. or you may have to call the operator, to get the code
Posted on Jun 24, 2014
Eu amm uitat codul de tel
Unlock Code
#*7337#
Entering Code instructions
1. Take out the SIM card from the phone and switch the phone on.
2. Enter the unlock code into your handset.
3. Now replace your SIM card and turn the phone on.
4. Your handset should now be unlocked.
Alternative Solution if the above fails
Unlock Codes
Code 1: *7465625*28782#
Code 2: *7465625*28638#
1. Remove SIM Card from handset
2. Enter Code 1 into the handset
(Your handset will display "auto subset lock activated")
3. Enter Code 2 into the handset
a) Enter an alternative network SIM card into your Samsung and reboot.
cool.gif The new network should be displayed in handset window.
c) If the process is repeated with yet another alternative network SIM card,
you may be requested to input a security or pin code to enable the use of
the new SIM card.
d) Enter 00000000 (8 zeros) which should enable the SIM to be accepted.
e) Finally once again enter 00000000 (8 zeros) and this should permanently
unlock the Samsung.
Final alternative Solution if the above fails
Unlock Code
#7465625*638*7337#
Jan 19, 2013 | Samsung SGH-i900 Omnia Unlocked Cellular...
Tip
How To Enter Unlock Code Into Motorola Mobile Phones Step By Step Instruction...
Model: All Motorola; check below for exception
1. Insert an unauthorized Sim Card and turn ON your phone
2. "Enter Subsidy Code" box appear
3. Enter Unlock Code
WARNING: If one of these messages appears:
- "Contact Service Provider"
- "Tamper Alter"
- "Wait before enter special Code"
- "Contact Service"
It's because you or somebody already enter too many wrong codes, you just have to let the phone ON at these errors message (do not close the phone if V3) and after 40 minutes to 12 hours, the message " Enter Subsidy Code" will appear again.
Model: A1000 and other A series model
1. Click on the Phone icon
2. Enter **057*
3. "Locking Enter Personalization" box appear
4. Enter Unlock Code
5. Press Ok
Model: L6i & L7i (NOT L6 and L7)
1. Press and hold * key and enter 787090
2. "Menu Network" box will appear
3. Select Yes
4. Press OK
5. Will ask for code
6. Enter Unlock Code
Model: All Motorola 3G network model
1. Enter **057*
2. Enter Unlock Code
Motorola CDMA & TDMA
1. Enter 74663# [Menu] [Menu] and you will be asked for a Subsidy Code
Unlock Motorola CLIQ (SIM Unlock) 1. Reboot your Motorola CLIQ with an unaccepted SIM card in.
*If the display reads "Enter Special Code", enter the unlock code and press "OK"
*If the display does not read "Enter Special code":
2. Press and hold the * key until an entry box is displayed.
3. Type *, #, 3, 2, # and press "OK"
4. Enter your Motorola CLIQ's unlock code and press "OK."
5. Your Motorola CLIQ should now display either "Completed" or "Deleted"
Motorola MPX
2. If the phone is asking for NETWORK PIN
3. Enter the NETWORK PIN
4. If the phone is asking for SERVICE PROVIDER PIN
5. Enter the SERVICE PROVIDER PIN
6. Your phone is now unlocked
Network PUK
If the phone is asking for NETWORK PUK: Power on the phone with the original Sim Card in and wait till phone is fully powered on and you have access to menu. Enter *#**364# and press green button. You will get an error message and thereafter, you will see an Engineering Menu:
1. Select Options
2. Select GSM Test
3. Select Send AT command
4. Now you will see a new window Saying "Send AT Command"
5. Enter AT+CLCK="PN",0,"[SERVICE PROVIDER PIN or NETWORK PIN]"
6. Press send
If you get Response "0 []" phone is unlocked. If you get 1 error, then make sure you have typed the code correct and try the other code. Turn your phone off, take battery out. Put battery back in. Power on the phone and leave it for 40 minutes to 12 hours until the message "Enter NETWORK PUK" is gone. Now enter the Unlock Code and 00000000 (eight zero's) as a new password
Service Provider PUK
If the phone is asking for SERVICE PROVIDER PUK: Power on the phone with the original Sim Card in and wait till phone is fully powered on and you have access to menu. Enter *#**364# and press green button. You will get an error message and thereafter, you will see a Engineering Menu: 1. Select Options
2. Select GSM Test
6. Press send
If you get Response "0 []" phone is unlocked. If you get 1 error, then make sure you have typed the code correct and try the other code. If you do not have the original Sim Card or if the original Sim Card is not accepted because you flashed the phone with other firmware, then we cannot help you
You can get the unlock code through online..........give your IMEI number and get the unlock code for ur mobile.... i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
on Apr 07, 2011 | Cell Phones
Unlock Motorola droid 2 To join new network
Hi, You can unlock a Motorola Droid 2 safer and easier using unlock code. You can get the unlock code for a Motorola Droid 2 from www.wickedunlock.com/motorola-droid-2/rs11wp9/ at affordable cost.
UNLOCKING STEPS FOR MOTOROLA DROID 2
1 - Switch ON your Motorola Droid 2 with a NOT ACCEPTED SIM Card,
2 - Phone will display "Enter Special Code",
3 - You can now enter the Unlock Code.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Motorola Droid 2 is locked to.
WARNING: If one of theses messages appear :
- "Tampert Alter"
- "Contact Service'
It's because you or somebody already entered too many wrong codes, you just have to leave the Motorola Droid 2 ON with the errors message and after 40 minutes to 2 hours the message "Enter Code Special" will appear again!
Oct 04, 2012 | Cell Phones
Asking for a restriction code
If your Nokia mobile phone displays Phone Restricted with an Undo option and selecting Undo results in an Enter Restriction Code error, your Nokia mobile phone is Network Locked. This means your Nokia mobile phone has been restricted for use on one specific network and a Restriction Code or Unlock Code must be entered before the phone can be used with alternative networks.
You can get the Restriction code at here
Superunlockcodes.com and Follow the instructions below and Unlock it step by step..
Nokia 2700 Classic Unlocking Instructions
Warning: Do not enter any wrong unlock unlock codes on your Nokia 2700 Classic mobile phones. If you enter over a certain amount of wrong unlock codes on your mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 2700 Classic without any sim card.
2 - Don't bother as to what is displayed on your Nokia 2700 Classic.
3 - Compose #pw+CODE+1#.
4 - The Nokia 2700 Classic would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 2700 Classic mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 2700 Classic
You can get the Free Unlocking instructions at here
Mobileunlockguide.com
Sep 01, 2011 | Nokia Classic 2700 Cell Phone
How can I get a sim network unlock pin for a t mobile Motorola blur
Motorola Cliq and Motorola Blur are same Phone Only!!
Then You need Network Unlock pin means
get the Network Unlock Pin from here
Mobileunlocksolutions and Follow the instructions below and Unlock it step by step!!!
Motorola Cliq Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your Motorola Cliq mobile phones. If you enter over a certain amount of wrong unlock codes on your Motorola Cliq mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Motorola Cliq with a NOT ACCEPTED SIM Card,
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Motorola Cliq is locked to.
- "Tampert Alter"
- "Contact Service'
It's because you or somebody already entered too many wrong codes, you just have to leave the Motorola Cliq ON with the errors message and after 40 minutes to 2 hours the message "Enter Code Special" will appear again!
Aug 29, 2011 | Motorola Mobility CLIQ Cell Phone
Can you still unlock a phone even if it says cannot undo restriction.
You can get the Restriction code here
Theunlockspot.com and Unlock it from Network Lock. Follow the instructions and enter the code correct step by step...
Nokia 2680 SLIDE Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Nokia 2680 SLIDE mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 2680 SLIDE mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 2680 SLIDE without any sim card.
2 - Don't bother as to what is displayed on your Nokia 2680 SLIDE.
4 - The Nokia 2680 SLIDE would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 2680 SLIDE mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
The CODE you need to enter is the unique unlock code for your Nokia 2680 SLIDE
Aug 06, 2011 | Nokia 2680 Slide Cell Phone
I NEED RESTRICTION CODE FOR 3110C 354206/03/720307/7
RESTRICTION CODE FOR NOKIA 3110C 351939039190487
Aug 06, 2011 | Nokia 3110 Cellular Phone
Unlock Network Pin For Motorola AT&T SKU C1681 IMEI 354656029204063
To unlock the Motorola C168I from the Network Lock ,get the Unlock code from here Onlinegsmunlock and Unlock it...
Motorola C168i Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Motorola C168i mobile phones. If you enter over a certain amount of wrong unlock codes on your Motorola C168i mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Motorola C168i with a NOT ACCEPTED SIM Card,
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Motorola C168i is locked to.
- "Tampert Alter"
- "Contact Service'
It's because you or somebody already entered too many wrong codes, you just have to leave the Motorola C168i ON with the errors message and after 40 minutes to 2 hours the message "Enter Code Special" will appear again!
Jul 10, 2011 | Computers & Internet
Unlock code
SIM Cards and Unlocking your Phone What is a SIM?
Subscriber Identity Module (SIM): A smart card containing the telephone number of the customer, encoded network identification details such as: Call Forwarding, Caller ID, etc., the PIN, and other user data such as the phone book. T-Mobile customers can move their SIM card from any T-Mobile branded phone to any other T-Mobile branded phone without the need to contact Customer Service to activate the new phone. Your rate plan and phone number will follow your SIM to the new phone.
SIM Error Messages:
  • Invalid SIM: This error means that the SIM you have inserted into your phone is either inactive or is not compatible with our service. You may purchase a new SIM card from a T-Mobile retail location. Locate a T-Mobile retail store near you.
  • Insert SIM: Your SIM is either not inserted in your phone or is inserted improperly. Please remove and re-insert your SIM card. If you continue to receive this error message, your SIM card or phone may be defective. You may take your phone and SIM to a T-Mobile retail store for further assistance and a free SIM card replacement if necessary. Locate a T-Mobile retail store near you.
  • Unregistered SIM: This error may occur if your SIM card is not fully activated or if the SIM card registered to your account is different than the SIM you have in your phone. For assistance with this issue, please contact Customer Service.
  • SIM Not Ready: This error occurs when you have just powered your phone and is due to the phone not being fully initialized. Please wait a few moments before accessing your phonebook or placing a call.
  • OTA OK: This message is displayed when your phone receives a network update, phonebook download, or an Over-The-Air t-zones or Picture Messaging configuration. NOTE: These messages are free of charge and will not be billed to your account or pulled from any text message bucket.
  • Enter PUK: These errors can occur if you have entered your SIM PIN three times incorrectly. If you receive this error message, please contact Customer Service for a PIN Unblocking Key (PUK) to restore access to your phone.
  • Check card, Card Blocked See Supplier, Blocked, SIM Blocked, or Contact Card/Service Provider: These errors may occur if you have entered your PUK ten times incorrectly. If these errors display your SIM is unusable and you will need to purchase a new SIM card. You may purchase a new SIM card from a T-Mobile retail location. Locate a T-Mobile retail store near you.
SIM PIN:
A SIM PIN can be used to prevent access to your phone. When enabled, your phone will prompt you for the SIM PIN when the phone is powered on. Entering the wrong PIN will prevent you from making or receiving calls. SIM PINs are different from a Security Code that your phone may use to secure other phone functions. Please check your phone’s manual for further security details.
T-Mobile SIM PIN numbers are set to default values before purchase. If you change your SIM PIN, it is recommended that you keep record of the new PIN in a safe location. T-Mobile cannot retrieve a lost or forgotten SIM PINs.
  • SIM PIN1: 1234
  • SIM PIN2: 5678 (Only available on select phones)
SIM Unlock:
T-Mobile branded phones operating on the T-Mobile network may only use T-Mobile SIM cards. To use a T-Mobile branded phone on another wireless carrier's network with a non-T-Mobile SIM card, you must first request a "SIM Unlock" code from T-Mobile. Conversely, if you have a phone from another North American wireless carrier, you may need to request a "SIM Unlock" code from that carrier before being able to use a T-Mobile SIM card on the T-Mobile network.
SIM Unlock Requests:
T-Mobile customers must meet the following eligibility requirements before contacting Customer Service to request your SIM Unlock code.
The following restrictions apply to all account types:
  • T-Mobile can provide SIM Unlock Codes only for handsets sold by T-Mobile USA, with the exception of Danger Sidekick devices. T-Mobile can obtain SIM Unlock Codes for companies acquired by t-Mobile USA (VoiceStream, Aerial, Omnipoint, SOL, Digiph, PCS One, and Powertel).
  • SIM Unlock Codes will only be provided after your account has been active for 90 days. Only one unlock code may be provided per customer every 90 days.
  • No SIM Unlock Codes will be provided within the 14-Day Buyer's Remorse period. Customers who purchase phones in CA California or via Amazon.com are granted a 30-Day Buyer's Remorse Period.
  • SIM Unlock Codes are not always available from the Manufacturer. However, T-Mobile will make a dedicated effort to obtain the SIM Unlock code. Note: Other restrictions may apply depending on account type.
Goodluck
Jan 10, 2008 | T-Mobile Wing™ Smartphone
Unlock
i want use it in egypt
Dec 12, 2007 | T-Mobile Wing™ Smartphone
Doro Phone Easy Logo
Top Doro Lands Phones Experts
Marvin
Marvin
Vernon Taylor
Are you a Doro Lands Phone Expert? Answer questions, earn points and help others
