SOURCE: Solution for canon ir 2520 error code E000020
E020 0000
The path between the sub hopper and the developing
assembly is clogged with toner.
1.Check the rotation of hopper motor gear. (If rotating, false
detection by the sensor is doubted. Feed the toner to the
developing unit in service mode: CLEAR>ENGIN>TNRINST.)
2.Replace the Developing Assembly Toner Sensor (TS1).
3.Replace the Sub Hopper Toner Sensor (TS2).
4.Replace the DC Controller PCB (PCB4).
SERVICE MODE:
* 28 * or MENU and #
SOURCE: canon iR 2520 toner install problem.
u can go in service mode by pressing additional function + 2+8 then go in clear by pressing scrolling, then go in engine. after press ok in tnrinst. machine will process for 2 minutes. for toner installation.
SOURCE: what it a finisher for
help me please , i fixed finisher ir2520 finished and i open power
finisher is runing left to righ,panel show aready about 2 secon
it show e000716, how can sobe.
SOURCE: solution to errorE000003 0f ir 2520
Press the additionel function button & press 2&8 buttons at once and again press additionel function .select COPIER and FUNCTION and CLEAR and ERROR andpress OK button.
SOURCE: Canon ir 2520 error e00000 000
How to clear E000, E001, E002 and E003.
1-Enter service mode by pressing additional functions than 2 than 8 and then Additional Functions.
#SSSW will be displayed.
2-Use the right arrow and scroll to #CLEAR then press OK.
3-Use the right arrow and scroll to ENGINE then press OK.
ERRCLR will be displayed then press OK.
4-Then power cycle the machine.
Service Mode : ADDITIONAL FUNCTIONS>2 KEY>8 KEY> ADDITIONAL FUNCTIONS>#CLEAR>ENGINE>ERRCLR.
Note: This mode should be used to clear all Fixing related Error Codes.
If this does not resolve the error code. / u need to call for service or if u are a tech--pull out the fix unit to inspect
