Need diagram for 2007 ford focus fuse box.
Samuel, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Check fuse if ok , hook up jumper leads to washer motor, if motor works repair or replace switch, if motor still not working replace it. All ways make sure the wiper tank is filled with clean water as a small amount of dirt can jam up the motor.
2002 lincoln continental tries to start, then drags down real bad and wont even turn fast enough to think about starting. If I wait a few minutes, it will do the same thing, about a full turn, fires, then drags down. Cant figure out what is causing this.
think its in the money tray you pull it out and fuse box behind it. think its a 10 amp. its like a pocket in the dash around knee height. i'm sure its there was on 2007 model.
often times the owners manual will tell you fuse box locations and give you a diagram to which fuse controls what, and what amprage fuse youll need to replace it with. if the manual doesnt tell you which fuse controls what, then the fuse box should have a diagram somewhere close by like on a cover to the actual box. if all else fails, google "fuse box location 2001 focus" and see where it is
There are 4 fuses you would need to check in the interior fuse panel.
The first one is fuse no.32(10amp) then check no. 33 (15amp) then no. 59 (7.5 amp) and no. 61 (7.5 amp)
