There is sound, and the white side will flicker occasionally with the rest of the image, although it is very washed out and faint like the other side.
Yes. There is a possibility. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
SOURCE: got a new T-con but no luck
is your back light constantly on when you are not changing channels.if so replace the main board. can you see a menu if you hit the menu button ? that is generated by your main board..... replacing the t-con will only correct vertical lines in the pic.
SOURCE: Samsunb 4051: TV screen turns off sound stays on.
Most likely this set has an "integrated" inverter, as most samsungs do--and this DOES sound like an inverter problem. Make SURE thought, there are no more bad "10 volt" caps on the power supply...ALL of them need to be replaced no matter HOW they look.
SOURCE: samsung LN-T4071F WASHED OUT ON LEFT SIDE WITH
CHECK LVDS CABLE FIRST, TAKE IT OUT OF THE T-CON BOARD FIRST AND RESEAT IT, THEN TAKE IT OUT OF THE MAIN BOARD SECOND, COULD GET LUCKY AND FIX IT, OTHER WISE THE SCREEN IS PROBABLY BAD
SOURCE: Samsung LCD model LNT4665F went
It sounds like you did not properly reinsert the ribbon cables, also verify that you do have 12vdc feeding the T-CON board, you may have to clean the contacts on the connectors also.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
SOURCE: Samsung Hp T5044 plasma tv has volume but no
I had a similar problem with my 42 in Philips LCD HDTV. Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems. Here are some options for you. 1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?) 2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found at tv-part.com but supplies are limited. I would definitely shop around though. 3. Remove and then replace individual faulty caps. This takes some soldering skill. Caps are inexpensive and if you can take care of it yourself it will save you hundreds. This may be your problem. If you determine that it might be. I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help. Hope this helps and if it does please rate it accordingly. Good luck.
