Question about Mitsubishi WS-55511 55" Rear Projection Television
My mitsubishi 55 in. rear projection tv has a very light contrast to it . Then turns to a regular pic
The pic usually starts out as if the bright contrast is too bright. Then it returns to a normal pic
Posted by Rocky Escobedo on
5 Related Answers
premtech
William Rayburn
  • 934 Answers
SOURCE: mitsubishi 55'' rear projection 1080i hd tv lense cleaning
Pry off the lower speaker grill... Remove the screws at the lower edge of the screen framing and lift screen frame of the two catches at the top. Be careful, there will be wires still attached to the front button panel... Then lay the screen down and support the bottom of it in some way because the button panel wires won't reach all the way... then using windex and papertowel cleam the mirror and lens(s) on each of the crts. Also clean the back or inside of the screen area and reverse the process to re-mount the screen.
Bill
Posted on Dec 19, 2007
MICHAEL MULLINS
  • 927 Answers
SOURCE: vs 4561 weak picture
Good Day, Techwanab;
Look for this to be your problem: CHECK FOR OPEN L2C50 PART #325C146030 ON THE SIGNAL PCB, OR BAD CONNECTIONS AND LEAKY CAPS IN THAT AREA.
Hope this was helpful and not too late.
Good Luck, big IRISH.
Posted on Jul 31, 2008
Anonymous
  • 10 Answers
SOURCE: PICTURE IS STRTING TO BEND AT THE TOP AND BOTTOM
This sounds like the most common thing that fails on projection TV's, regardless of the brand. The convergence circuit has two, or sometimes three STK IC chips mounted on heat sinks to drive the convergence yokes. They typically last anywhere from 5-10 years, then they fail. It sounds like in your case, the solder joints on the bottom of one of these chips may be failing and some fresh solder will make it go for a while. If it was my set, I would go ahead and replace both STK chips once I took the trouble to take it apart.
Posted on Jul 06, 2009
SD Tech
SD Tech
  • 14553 Answers
SOURCE: Misubishi Medallion 1080
If this is a ws-65411: it sounds like one of the two STK-392-110 convergence IC's is bad; you need to have both replaced at the same time; I do this type of repair(done hundreds of them) and most can be done right in your home.
The two ic's can be purchased on Ebay for about 12 dollars plus shipping.
This is the slow time of year for TV repair shops--find someone in your area who knows how to do this kind of repair---here shops charge 3-4 hundred but I charge 200-250 total depending on brand of set.
Shop around and if they insist on "taking set to shop" keep looking---any good tech can do this repair in your home---MAKE SURE HE CHANGES BOTH of the IC's!
I do this here for free so if this has been helpful give me a vote here.
Posted on Aug 24, 2009
Testimonial: "very helpful"
milkburp
Adam Halfhill
  • 416 Answers
SOURCE: Screen is dim. Have brightness turned up to max
Yes... from the moment the lamp is put into service, it begins to deminish in brightness. You should order a replacement lamp to have on hand.
Posted on Mar 15, 2010
White shadows
Usually it is normal but if contrast set way too high that can also cause it.
set bright at about 70% and contrast a bit lower.,
Mar 12, 2012 | Mitsubishi WD-62525 62" Rear Projection...
Just bought a Mitsubishi WD-52526. With Brightness, Color, Sharpness, Contrast, Everything Video turned all the way up the Screen is still very dim. Is this a lamp issue?
It could be. Do you know if the previous owner ever changed the bulb? If not you may have to replace it. The bulb usually costs around 160ish. I would try it and see if it helps the brightness.
May 04, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Dark pic on screen, unable to correct with regular means.
Regardless, my answer stands. It needs repair by a qualified technician. Rates vary by area. Make telephone inquires.
Jan 09, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Pictue to dark
Try pushing the video button on your remote.
Jan 04, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Loewe articos hd tv rear projection. contrast too shiny
Try lowering Brightness first.Not contrast leave it up middle range.
Dec 26, 2008 | Loewe Articos 55 55" Rear Projection...
Wd-62825 mitsubishi dlp tv
Had the same problem. Service replaced the lamp engine. It did help.
Dec 18, 2008 | Mitsubishi WD-62825 62" Rear Projection...
Sharp LC-32DA5U
sounds like youve had a pic tube go out,,probly just one and the other 2 are still good,,thats why it came bck on,,take it to a tv shop ,know ,,want be that much if its just one pic tube,,good luck
Oct 05, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Have mitsubishi with same problem blinking light
try unloading convergence yokes and and turn tv on if turn on your problem convergence IC's
Apr 01, 2008 | Mitsubishi WS-55859 55" Rear Projection...
TV shuts off with high color images . Example: explosions,bright lights etc
Normally, the screen control being up a little to high, would cause this problem. If no one has worked on this unit when it started may be a sign of something else, for example, the 200 volt line may be running a little low. Check the brightness and contrast for starters and if that doesn't help, then, the screen control would be my next step. Hope this helps.
Jun 03, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
56 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
