Question about NorStar Meridian M7310 Phone
I have a Nortstar M7310. The Main Greeting is set up and it gives 4 options and #4 is for a list of company employees. I need to re-record this since we have new staff and can't find it.
I can access the main greeting but can't find where anything else is to re-record it. We have the main greeting, a recording of menu options, and then a recorded staff list.
Rory DiSante
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 18 Answers
Reset voicemail box and when the set up the voicemail on there phone and record there greeting make sure they record there name as well then it will play the extensions recorded name
Posted on Apr 05, 2020
5 Related Answers
Anonymous
SOURCE: Main company greeting....
I figured it out.
Feature 983
Network Password: if you are using 4-digit extensions: 10020000, 3-digit: 1020000, 2-digit: 120000
Press OK
Press AA
Press GRTG
Press GRTG (again)
Press the number for which the greeting is located - I guessed that mine was "1" and i was right
Press OK
Then you have the option to PLAY that greeting or RECord a new one
I hope that helps.
Posted on Nov 21, 2008
ynotphone
ynotphone
  • 192 Answers
SOURCE: Change/record the Directory Options on M7310
Can you get into the voicemail?
If you cannot get in, there are ways to erase the current password, back to the default password of: 0 0 0 0
If you can get in; after you dial your Password, press 8 and listen to the prompts.
There will be a prompt to change your name, one for your password and another for greeting.
Posted on Apr 01, 2009
Anonymous
SOURCE: Nortstar M7324
In order to record an alternate greeting, you sign into your voicemail. Select Admin, Select Greet, Select Choose (and select which greeting you would like to use eg..Prime or Alt) Once you select the greeting. The voicemail is set to use that greeting. To record that greeting, go back into Admin, Select Greet, Select Rec, and record and save your greeting.
Posted on May 11, 2009
consultel1
george peters
  • 860 Answers
SOURCE: Changing the greeting on the company's main phone
To re-record greetings, enter Feature 983. if your system has 2 digit intercom #s your default password is 120000 if your system has 3 digit intercom #s your default password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting 1. press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished
Posted on Dec 18, 2009
consultel1
george peters
  • 860 Answers
SOURCE: need directions for recording the greeting on the
To enter voicemail administration, press Feature 983. if your system has 2 digit intercom #s your default password is 120000 if your system has 3 digit intercom #s your default password is 1020000. Once you have entered the password you will see 3 selections you can make .Use the three soft keys under the display and select AA (auto Attendant). Next, press greeting and greeting again. Next, it'll ask for the greeting number your probably working with greeting 1. Press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished
Posted on Sep 30, 2010
How do I toggle between day greeting and night greeting? Our s seems to be stuck on night and I don't know how to switch it back/toggle it. Just started at this company and no one knows how to use the...
Night feature at reception set or set that you put night service on go Feature #87. For delete of mailbox Feature 983 enter password which should be 1020000 if 3 digit extension numbers or 120000 if 2 digit extensions. Then press mbox then del enter extension number then press del.
Feb 13, 2015 | NorStar M7310 Corded Phone
Auto attendant mystery greeting - can't find in greeting tables
I wasn't able to find anything specifically related to additional greetings or recordings, but I did find the manual for that particular phone model in .pdf format. Here's the link, good luck with it:
http://www.aicag.edu/wp-content/uploads/2013/09/Norstar_M7310.pdf
Dec 16, 2013 | NorStar M7310 Corded Phone
The automated recording that comes on when the lines are full needs to be changed and the recording of an employees name on the directory needs to be changed. I have already changed the display name on the...
The persons name is recorded in their personal mail box.Thats done by pressing open voicemail or feature 981 followed by their password, press 8 or admin and press 1 to re record thier name in the company directory.
To re-record greetings, enter Feature 983. if your system has 2 digit intercom #s your default password is 120000 if your system has 3 digit intercom #s your default password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting 1. press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished.
Apr 06, 2010 | NorStar M7310 Corded Phone
Dec 17, 2009 | NorStar M7310 Corded Phone
How do I change the main greeting from greeting 1 to greeting 2?
You have to go to vmail prog. Press feature 983 from main tel set enter passwrd press aa press greatings type in a 2 record your greeting you will have to rerecord over greeting 1 if you want to chg it .you know how to assign it to a time of day greeting table if not give more info
Nov 24, 2009 | NorStar M7310 Corded Phone
Apr 01, 2009 | NorStar M7310 Corded Phone
Automated Attendent
Norstar Voicemail for 6.0 or less
Programming must be done from any M7310, T7316, or M7324 model phone set.
To Log Into System Administration:
1. Enter Feature 983
2. The display will show "LOG:", enter your login password
a. If your company extensions are 2 digits long enter "120000"
b. If your company extensions are 3 digits long enter "1020000"
c. If your company extensions are 4 digits long enter "10020000"
3. Press the softkey under "OK"
To Record the Company DAY & NIGHTGreetings:
1. Press AA
2. Press GRTG
3. Press GRTG
4. <Display> Greeting:
5. Enter 1 for DAY Greeting --- Enter 2 for NIGHT greeting
6. Press OK
7. Press REC to record.
Feb 25, 2009 | NorStar M7310 Phone
M7310 nortstar telephone
Normal 0 To Log Into System Administration:
2. The display will show "LOG", enter your login password
Aug 27, 2008 | NorStar M7310 Corded Phone
Nortstar M7324
May 30, 2008 | NorStar M7324 Telephone
Resetting company voicemail
Norstar Common Voicemail Features To Check Your Voicemail:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. From here you can listen to messages, change your greeting, change your password, etc.
To Leave a Message for Someone in Your Office:
1. Press the Leave Message key or Feature 980
2. Enter the mailbox number (extension number. of the person you want to leave a message for
3. The display will show the name of the mailbox owner, press OK
4. Leave message
To Access Your Voicemail box from Another Phone:
2. Press the OTHER softkey
3. At the LOG: prompt, enter your mailbox#(extension #. and your password all together followed by the "#" sign
4. Press the OK softkey
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your voicemail box
3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
To Transfer Someone to a Voicemail Box:
1. Press the Transfer to Voicemail key or press the Feature button, then 986
2. Enter the mailbox # (extension#.
3. The display will show: Call Transferred
To Change Your Personal Greeting:
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
To Record Your Alternate Greeting (Used when on vacation or out of the office.:
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the ChOOSE softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting
took this from a guide i have, might help you guys out
Jan 07, 2008 | NorStar M7310 Corded Phone
NorStar Meridian M7310 Phone Logo
199 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
martin hogg
Ekse
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
