Refrigerators Logo
Leigh Parisi Posted on Nov 03, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The ice maker of our GE GSH25JSXSS is only producing crushed ice even when it's set to cubed. Is there a way to fix this issue?
FOr some reason the setting will not recognize cubed. We can press it and the light illuminates, but still gives crushed ice.
John Tripp
Level 3:
  • GE Master 4,656 Answers
  • Posted on Nov 05, 2015
John Tripp
GE Master
Level 3:
Answers
4656
Questions
Helped
1677665
Points
14883
Check that the shifter bar on the bottom of the ice bin is moving to shift from cubed ice to crushed. With the ice bin out you should see movement in the back wall of the freezer with the light switch button held in while changing the dispenser controls from cubed to crushed. GSH25JSXASS Parts
Ice Bin Parts
Appliance 911 Sea Breeze
My Crosley Conservator Ice maker will only produce crushed ice, HELP!
Ensure the Wire Signal Arm is not in UP position. • Ice maker should produce 2.5 to 3 pounds of ice in a 24 hour period. • Water supply is turned off. • Water pressure is too low. • The freezer is not cold enough.
Ge refrigerator sise by side tfx274 ice maker only gives crushed ice and no cubes
you have bad solenoid, it is a small part next to the motor behind the ice bucket. It lifts up the arm to let the cubed ice out of the dispenser bucket.
The ice maker works, but even in cube mode, it crushes the ice.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
1helpful
2answers
Icemaker dispenses crushed ice when you select cubed ice
GE has a problem with the flap on the door which lets the ice out , not closing due to a rusted solenoid behind the panel . If this flap does not close , frost will get inside the ice bin , not letting the bin flap open to let cubed use come thru, only crushed . You can defrost the ice bin front and replace the door flap solenoid easily . If this is the problem , repost about replaceing the flap solenoid for further instructions if needed .
8helpful
2answers
Ice maker crushes even when it is in the cube
If you pull out your ice bucket and look on the bottom you will see a long brass colored rod. Now, if you look inside your freezer section. you will see the slot the rod enters each and every time you insert your ice maker bucket. In the down position (normal) it produces crushed ice, When you switch the lever in the front for ice cubes, there is a plunger that lifts the rod and produces the combination that only allows ice cubes to come out. I would first check the plunger behind the panel and see if it is free.If it is not free it can cause the ice to be crushed...
Ice maker not working on GE side by side
heatman101
iyooyi76
Cubed Ice selected, crushed ice comes out
ice maker works. water thru the door works. lock works. light works, alarm works.
when i try to get crushed, ice cubes or quick ice.
nothing happens
17helpful
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
23helpful
7answers
Ice Maker Issues-only crushed ice works, cubed comes out crushed
There is a solinoid in the freezer section by the motor that turns the ice auger. Test it by selecting cubes and with the ice bucket out, open the door, hold the door switch so the lights turn out and push the dispenser button. It should make a loud snap and travel upward. If not then I would say you have a bad solinoid. If it does, then I would look at the bucket. the metal rod that runs along the side of the bucket opens a flap in the bucket that is supposed to let the full cubes drop. look for anything that might cause it to be hanging up.
Top Refrigerators Experts
vince
Johnny 1000
