Refrigerators Logo
C
Curt Posted on Nov 03, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Superba 10 yr old fridge is blowing condensation from the bottom back vent onto wall. how do I fix so that we can still make ice and water?
  • Curt
    Curt Nov 04, 2015
    figured out that the leak was spraying from the water line and then being blown out on wall by exhaust fan. replacing plastic water line
Vernon Taylor
Level 3:
  • KitchenAid Master 7,446 Answers
  • Posted on Nov 04, 2015
 Vernon Taylor
KitchenAid Master
Level 3:
Answers
7446
Questions
0
Helped
1955980
Points
26207
Probably not condensation but run-off water generated by the auto-defrost.
This water should drain through a tube into a tray attached to the motor where heat from the motor operation causes it to evaporate.
Sometimes the drain tube or the tray becomes detached.
If condensation is forming on the outside of your fridge it indicates the internal insulation jacket is failing and repair is impractical and replacement of the fridge is desirable.
Kenmore 596 bottom freezer forms ice at the bottom above and on the vents. Then we turn off and water comes down through ceiling in rec. room from defrosted freezer. how to fix?
sounds like a clogged or plugged evaporator drain line
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Side by side - there is water leaking bottom of fridge and then onto the floor- how can I fix?
2answers
Is it worth fixing a 10 year old KitchenAid Superba side by side?
Pull it out... - turn OFF the water inlet valve..
........... if it still keeps everything cold,,, keep it,,
My freezer frosted over everything because the door was not shut tight and now it will not clear.
take out all the food out of the freezer,unplug the fridge and get a hair dryer and start melting out all the ice in the freezer,then blow the hot air into the vent holes on the back wall until you don't see any more water dripping down through the slots in the back wall.turn the machine back on,open the fridge door after around 5 or 10 minutes and if you feel cold air blowing into the fridge you fixed the problem,if you don't feel cold air keep hitting the inside back wall with the hair dryer and keep blowing the hot air into the holes in the back wall.all that it does is the freezer gets cold and there's a fan behind the back wall in the freezer,the fan blows the cold air into the fridge side,if the air ducts are frozen the air can't circulate into the fridge section so you have to melt the ice out so the cold air can blow from the freezer to the fridge.good luck,if you have another fridge remove the food and unplug it and leave the doors open for a day and it will melt out.good luck
15helpful
No air blowing into fridge, although we can hear blower. Freezer is working
if you can hear the fan still blowing but no cold air coming up to fridge section a common problem with bottom mount freezers is the door gets left open and the air ducts freeze up and the air can't blow up to the top.turn the control off in the freezer.remove the top shelf and the door,check to see if there are any screws one on each side of the slide arms,if there are remove them and lift the door up and out,with a hair dryer melt out the ice by blowing the hot air up each side of the back wall,also if the back inside wall of the freezer is covered with ice or like snow then you have a defrost problem but if there's no ice on back wall do what i said and blow the air up the sides of the back wall through the vents until no more water is seen dripping through the vent holes,then turn the freezer back on and check to see if you feel cold air blowing in through the vents in the fridge section,if you feel cold air then you're all set,if not keep blowing the hot air up the sides until it's melted out.let me know what you find,you'll know if the door was left open,ice will be on the ceiling near the light switch and sometimes on the top of the freezer door
2helpful
Water is leaking from the bottom of the fridge.
Your fridge has likely gone through a defrost cycle. What frost was present has been melted and drained into the tray. During this cycle, the walls of the freezer are warmed up as well to facilitate melting the ice.
The air blown from the condenser fan should be blowing across the collection tray, and will evaporate the water in a short time. If you think that there is too much water, or it has started to over flow the tray, you can try scooping the water out using a small cup, or place the corner of a large towel into the water to soak it up. In either case, turn off power to the fridge first.
2helpful
3answers
Maytag Plus MTB2456AEW leaks from inside refrigerator onto the floor.
condensation- bad door seals. replace seals.
in fridge- condensate drain plugged. unplug drain under coils.
under fridge- condensate pan full. empty pan.
2helpful
Fridge isn't cold, but freezer is working fine
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
5helpful
10 yr old GE side by side: freezer is leaking
Your drain is frozen up and so every time unit goes into defrost the water refreezes in the freezer's bottom. You either have to shut fridge off completely and let it dethaw or use hot water and an ice pick to hurry up the process. The drain is located in the very back of freezer. You will have to pull out the bottom drawer to see it. Good luck
3helpful
2answers
We have condensation inside our frig
I fixed this issue!!!
Water was leaking from inside my fridge. This was happening because the condensation drain was iced over. Where is this drain? To get to it, first remove the crisper bins from inside your fridge. Then remove the back panel by removing 6 screws: 2 at the bottom corners, two on the sides, and two behind each light bulb. The panel might require a little effort to unstick from the back of fridge. After removing the panel, you will see the condensation coils (they're cold). You will also find some ice and water in a collection area below the coils. Normally, water falling from the coils will land in the collection area and pass through the slits at the bottom to a pan below your fridge where it can evaporate. In my case, ice was blocking the way causing the water to backup. To fix it, I removed the water with a rag, then used a hair blow drier to heat the collection area and melt the the ice (including the ice out of site in the drain). After a few minutes, I was able to pour water into the collection area and it passed through!
This is a pretty easy fix. All you need is a screw driver, a hair blow drier, and about 30 minutes.
Top KitchenAid Refrigerators Experts
vince
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
