SOURCE: Bobbin stuck on bobbin winder, how do I get it off? it will not budge!
Is thread under bobbin? can you turn it? can you pull the thread off the bobbin and then remove it? Bobbin that comes with machine may not be right one. Right one has a light blue tint and a slightly domed top.
SOURCE: bobbin winder wont engage properly
Just click below for the guide how to put the needle ;
Sewing Machine 101- Sewing For Dudes (and Ladies) No. 2: Stitches ...
Anatomy of a Sewing Machine. 1) Bobbin winder 2) Spool pin 3) Thread guide 4) Tension Knob 5) Foot and needle 6) Bobbin housing regards,
Hope it may helps you;
Regards,
VOTIT
SOURCE: singer 328k bobbin winder replacement
Follow these instructions, undo the 2 screws on the right hand side plate where the balance wheel is and take the plate off, undo the screw on the chrome stop motion wheel, undo the stop motion and take it off, take off the 2 pronged washer and notice which way it goes on, not a problem if you can't remember, you should be able to pull the balance wheel back so you can get to the screws on the winder, if you can.t and if you have a problem getting the balance wheel all the way then go the very bottom of the machine and you will see 2 big holes and one of the holes will lead you to a big screw and nylon adjuster, slacken the screw and move the nylon adjust so the belt goes slack, you can not take the balance wheel all the way off to get to the screws on the winder, take the old one off and screw the new one on, whilst you have the balance wheel off it would be wise to put some thin oil on the shaft before you put the balance wheel back on, when you have the balance wheel on and the and the belt round the pulley turn the nylon adjuster so the belt is tight and tighten up the screw, put the side plate back on, put the 3 pronged washer back on, put the stop motion wheel back on and just tighten finger tight then tighten the small screw.
You can turn the screw on the top of bobbin winder tad to right. Also, you may want to try a metal Universal bobbin, but try first option I gave first. Jimmy
