Question about Sharp CD-BA150 Shelf System
Sharp CD-BA150 error code 0306
CD player doesn't respond to any key or remote inputs
Posted by Whitneyville1 on
1 Related Answer
Anonymous
SOURCE: I am getting an error
For the error 0306, simply remove the lid of your system and clear the dust out/off of the lense and surrounding areas. (i.e. soft cloth, canned air, ect...) Hope this helps!
Posted on Feb 07, 2011
My renault megane remote sensor key doesn't respond when i press it.There is a signal showing red on the dash board which indicates that unless the remote sensor key is press two times,but still i
I would suggest you check the batteries of the remote. If you have replaced them it is possible that the microswitch on the remote might have worn out. Should be a quickfix at a locksmith that has the equipment to test remotes frequency. Good luck
Jan 12, 2018 | Vehicle Parts & Accessories
TV will not respond to/recognize remote. I have
Check On the Menu Setup for On/Off Remote utility Maybe your Remote signal is off on the TV Set...
Sep 22, 2010 | Mitsubishi WS-65611 65" Rear Projection...
The remote for my Panasonic HT520 doesn't respond. When the CD-DVD button on the remote is pressed the lights come on on the remote, but still nothing from the player. The player works fine on it's own,...
Ok let me verify; you have an HT-520 home theatre with integrated DVD player. When you press the DVD input you can't control certain aspects of the DVD player or the DVD player does not respond at all?
Does the DVD respond at all if you put the remote into another mode (should be called Amp or Receiver)? Can your remote be programmed for different devices and mabe it was programmed to control a different DVD player?
I will search the unit in my knowledge base and let you know some exact steps to try. If you could clarify some of thoes details that would be wonderful.
Thanks,
Kevin
Jan 24, 2010 | Televison & Video
Doesn this unit have a AUX input in the back?
no its on the lead that is supplied with the stereo
Nov 01, 2009 | Sony CDX-R3000 CD Player
Sony rdr gx360 only responds by displaying "DVD3" to remote cntrl
http://www.docs.sony.com/release/RDRGX360_EN_ES.pdf
Page 23 in the manual. Had the same problem. Press and hold ENTER and 3 for at least 3 seconds. Problem fixed
Dec 17, 2008 | Televison & Video
Kenwood kdc-mp528
You must have the remote to clear the security code. It will not work by using the keys on the display. here is the method of clearing the code.
1. When you are requested to enter the security code, while
pressing down on [AUTO] key, use a long-press on "track forward >>I" key
for 3 seconds. (----disappears.)
2. Using the remote controller, input “KCAR.”
Press remote controller [5] key 2 times and then press "track forward >>I" key. (Input for “K.”)
Press remote controller [2] key 3 times and then press "track forward >>I" key. (Input for “C.”)
Press remote controller [2] key once and then press "track forward >>I" key. (Input for “A.”)
Press remote controller [7] key 2 times and then press "track forward >>I" key. (Input for “R.”)
3. The security is released and the unit enters the STANDBY
sourcing mode.
4. If a wrong code is input, the unit goes into the Code Request
mode.
If you do not have a remote, you can take it to an authorized kenwood service center and they can do it for a small fee. My shop charges $25. Or you can order a remote from them and do it yourself, or borrow a remote from a friend who has a recent Kenwood model radio, they all work with it if the radio is new in the last 5 years or so.
Since this will clear the code if done properly, a rating of "FixYa" would be appreciated.
Thanks and let me know if you need any more help.
Dave
Jul 04, 2008 | Kenwood KDC-MP528 CD Player
Code Problem with a kenwood kdc-mp232 car audio
• How to clear the programmable security code (For models
of destination “K”)
∗ Operation 1
1. While “– – – –” is being displayed, press [->> ] key for 3
seconds or longer while pressing the [AUTO] key. This
makes the “– – – –” display disappear.
2. Input “KCAR”, using the remote controller.
Press [5] key of the remote controller twice (Input for “K”)
and press [->> ] key.
Press [2] key of the remote controller 3 times (Input for
“C”) and press [->> ] key.
Press [2] key of the remote controller once (Input for “A”)
Press [7] key of the remote controller twice (Input for “R”)
and press [ ->>] key.
3. The security is cleared and the unit enters STANDBY
source.
4. If wrong codes are input, “– – – –” will be displayed again.
Jan 03, 2008 | Kenwood KDC-516S CD Player
KCD-X590 is looking for a code that i never put in, and i bought the deck brand new
Method of clearing the programmable security
code (KDC-MP632U/X590)
1. While "– – – –" is being displayed, press [->> ] key for at
least 3 seconds while pressing [AUTO] or [TI] key.
This makes "– – – –" display disappear.
2. Using the remote controller, input "KCAR".
Press remote controller [5] key 2 times (Input for "K") and
then press [->> ] key.
Press remote controller [2] key 3 times (Input for "C") and
then press [ ->>] key.
Press remote controller [2] key once (Input for "A") and then
press [->> ] key.
Press remote controller [7] key 2 times (Input for "R") and
mode.
4. If a wrong code is input, the unit goes into the Code Re-quest
mode.
Oct 14, 2007 | Kenwood KDC-X590 CD Player
Top Sharp Audio Players & Recorders Experts
Bill Boyd
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
