Televison & Video Logo
Question about JVC Televison & Video
Model c-13910. Does it have a digital tuner?
Bought a clear TV HD digital indoor antenna.
Tim Brauer
    Sergeant:
  • 152 Answers
Most crt tv's such as this do not have digital tuners built in and would require a set top box to receive digital signal i know that in Australia where i am we no longer use analog signals so all tv's must have a digital tuner or set top box in order to still work
Posted on Nov 03, 2015
5 Related Answers
Anonymous
SOURCE: IS MY TV DIGITAL?
Unless you are connected to a cable TV or satilite provoider you will need a digital converter box connected between your tv and indoor antenna to recieve the new digital over the air signal
Posted on Jan 24, 2009
Anonymous
  • 4 Answers
SOURCE: no signal on digital TV
If you are talking about over the air digital channels I would lean toward ant problems
Posted on Apr 26, 2008
Anonymous
SOURCE: I have a Westinghouse 26 inch TV.
I carried my Westinghouse TV to the basement. Unplugged the antenna from the digital converter box and connected it to my digital TV. I then re-scanned for channels and found channel 9. After carrying the Westinghouse TV back upstairs, I connected the original set-up and tuned to channel 9 which was now showing on the screen as no signal. From that point I moved my VHF dipoles until I had located the correct position for reception. A little labor intensive, but I was fortunate to have another antenna that was receiving channel 9.
Posted on Feb 20, 2009
Anonymous
  • 33 Answers
SOURCE: tv set just lost its ability to display digital channels
Your problem is definitely the input signal source to your tv. It is extremely rare where a new tv has a tuner signal sensitivity problem. The best thing to do is to replace your current set of rabbit ears with a different set of powered rabbit ears that have a higher gain rating with a variable gain control. Please note that the gain control setting is critical when setting up your tuner for auto-programming. If the gain control is set too low or too high it will result in your symptom.
If you still can't get it to work you could try buying a line amplifier which you would install to the rabbit ears before the tv. If you still can't get it to work you'll have no choice but to purchase an outside antennae as a result of your being in a weak signal area as signal quality changes by such things as the switch over to digital upcoming and environmental changes.
Posted on Apr 27, 2009
Anonymous
SOURCE: Indoor antenna problem with Magnavox LCD TV Model 15MF605T/17
I have found most of these indoor antennae to be ineffective and a waste of money, however, I do not know anything about this particular antennae. I to have a Dish DTVpal, which I love! It's ugly and probably won't fit in your kitchen, but the best solution is to make your own "bow-tie" antennae, mount it indoors or on the roof and run a cable to the kitchen. Directions can be found on You-Tube. I live in SE Idaho (Pocatello) and can get 13 channels, most without having to adjust the antennae.
Posted on Feb 26, 2010
I keep gettin "no TV Signal" on my Emerson EWL20S5C when i plug in a indoor tv antenna. DoI need a converter box. I live very close to tv towers. HD
I cannot seem to find info on the version "C" model, but everything I find on the base model appears that is is not a digital unit and does not have a digital tuner. Thus it would need a converter box to tune digital HD channels. That said, the specs also say that the set can handle 480p/480i/1080i inputs. Thee is no mention of 720p/720i/1080p capability, which funnily enough, most US TV HD broadcasts are in 720p or 1080p. You may find you need a new set.
How do ihook up a digital antenna to my tv
Dominic, you do not state whether you want large outdoor antenna or simple indoor.
If you bought your HDTV anytime during the past 8 years or so, it should have a built-in tuner for receiving digital over-the-air broadcasts. If you have an older "HDTV-ready" TV that only receives analog signals, you'll need to connect it to a separate HDTV tuner.
link below tells how to install outdoor digital TV antenna.
press the helpful button.
How to Install Digital TV Antenna Digital TV Help
How do i get hd channels with no cable ? just antenna
If your TV has a digital tuner, you can get any HD channels if you use the correct antenna pointed at the transmitter and are close enough to the transmitters. (Antennas labeled as HD are not always appropriate for your location.) Your TV will downgrade the signal to 480i if the TV can't support a 720p or 1080i resolution.
First where do you live? Use antennaweb.org or tvfool.com to determine the correct placement of your antenna for your area/stations. AntennaWeb uses a very conservative signal strength calculation despite assuming an external antenna. Tvfool will give the antenna color rating which is also provided on the antenna package. When properly installed (with no trees or hills blocking the signal), the matching antenna should receive the listed channel.
If you use a splitter to share the signal with several TVs, you may need an amplifier to bring the signal strength to that needed for the tuner to interpret the digital signal. (Note: amplifiers and splitters can fail and the amplifier may become a signal filter blocking the signal; test the antenna strength on a direct connection if there is a problem.)
If you do not have a digital tuner in the TV, you may have gotten an SD digital to analog converter. These are the more common (and available with the government coupon) converters. You will need to get an HD capable tuner to see the full HD signal.
Please add a comment with your TV model and antenna choice for additional support.
(antennaweb indicates that my external antenna should only get the stations 10 miles away. We actually receive the channels from 30 miles away. We use an amplifier splitter to feed the signal to several TVs. I set up two indoor antennas for a neighbor's TVs. One gets the signals from the transmitters 30 miles away and the other from the transmitter 10 miles away. Both get HD from the stations with HD broadcast (not all channels are in HD here). The difference is totally due to antenna placement.)
2answers
Tried to hook up a HD antenna but it won't work
HD is pretty critical and if a indoor antenna do not expect much or anything for that matter.
Why can't I get reception on my TruTech tv model DW19TT even after plugging in a Phillips digital indoor tv antenna
If the antenna is working and you are not receiving a signal, then you could have a bad tuner, use a tuner from a VCR , connect the ant to the VCR and go from the VCR with Video cables and go to the Video input on the TV and put your TV in Video mode. That will work.
I have a RCA D52W20 rear projection HDTV. This TV was purchased in2005. I cancelled my cable and I just hooked up a digital antenna but the TV isn't finding any channels. What do I need to do? I was...
HDTV indicates the number of lines that are shown by the TV. (HD means that at least 720 lines can be displayed in a given picture.) To receive OTA signals, you need an ATSC tuner (digital) of sufficient power (with a clear path to the transmitter) these days. The RCA D52W20 was released in 2002 and only has an NTSC (analog tuner). You will need a digital-to-analog converter to receive OTA TV (unless any low power analog stations remain in your area).
Please note that the basic digital-to-analog converters that were available with the government coupon back in 2009 were SD (480i lines of pixels used) units. HD d-t-a converters exist but are more expensive.
I hope this helps.
(the phrase "digital antenna" is meaningless; check with tvfool.com or antennaweb.org for the direction of local transmitters. TVfool.com will give more information on the type of antenna (indoor, outdoor, amplifier) that you will need to receive channels in your area. Antennaweb assumes an external antenna but is very conservative in the stations that it will indicate that you can receive. Antennas are given a color rating based on how far away the transmitter can be to get a watchable signal. Since digital signals are either enough for the tuner to interpret or you get a "no signal" message, you often need a stronger signal than was needed to receive a watchable analog channel.)
I just bought an outdoor/indoor antenna and it will not let me get no channels?
Post the model of the television and the model of the antenna.
Your TV may not have digital tuner and the antenna that you bought may not be for digital television.
2answers
IS MY TV DIGITAL?
yes you will. either install an outside antenna or get a good amplified indoor antenna. try your old antenna first, but when your picture freezes or it says something like " weak signal " you will need that new antenna
No TV Reception
Sony Technician confirmed that that the TV has an analog tuner
2 options - outdoor antenna with digital converter --- or cable service
HD ready?
The TV is just HD ready (doesn't have the HD tuner built-in), you need a separate HD tuner connected to your TV.
Top JVC Televison & Video Experts
Marvin
Marvin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
