Bottom oven and burners all work fine.
I would think you need to replace the upper ignitor
I’m happy to assist further over the phone at https://www.6ya.com/expert/howard_977676954994c5b2
Hi Larry
Use a multimeter on AC range to test for voltage on wires going to bad element.
It's probably a bad switch or open element.
Elements often unplug for replacement. Don't always show damage of burned out conductor. So... Use your multimeter on the ohms scale to test for continuity at each end.
Upper oven element is likely open circuit and will need to be replaced.
Cheers
