The float in your carburetor is stuck, not allowing the needle valve to close in the seat and stop fuel flow. Gas is bypassing the needle, and filling the crankcase. Rebuild Carb, Drain crankcase oil, and replace oil filter. Fill with fresh oil, and problem is solved.
Sounds to me like the float needle valve in the carb is leaking. This will cause fuel to over flow out of carb, and will even get into the engine oil. Check to be sure that float is not got gas in it the can go bad. Also check float adjustment. Check needle and seat very carefully for dirt or wear. Just the slightest bit of dirt or wear can cause it to leak. Hope this helps.
your oil pump does that on purpose - more noticeable with a dented oilpan as pressure is slightly increased. nothing to do until it goes (if it goes) unless you want to throw parts at your car anyways.
You need to oil your cables first....They make a gadget to help you do this...it clamps around the end of the cable, and you spray oil into a provided hole for a spray nozzle tube...Then see if the cables are unstuck by turning the throttle grip back and forth for awhile....start it and see if that helped....if not you may need to replace the cable(s)...I doubt that the slide in the carb is hanging up...or valve.If this doesn't work notify me.
