Turning timer by hand gives sounds normal for cycle. Does not shut power off for dry cycle. Power to motor is constant. pulled cover off, had to turn metal tabs at timer to get metal panel off, timer appears to be glued to door back . Can't get at timer to check contacts. Stumped
Anti flood device in a lot of german machines and pump keeps running only way to knock it off is too un plug what has happened water has leaked possibly over a period of time ,and set the anti flood device off if ya disconnect macine plug and drain hose and lie on its side water will drain off anti flood put some towels to catch water and macihne should work after ya reconnect
SOURCE: Bosch dishwasher is stuck on drain cycle
cause is water in the bottom tray which operates an anti-flood switch and all machine will do is drain.
disconnect from mains
remove bottom panel and mop out water and it will work. if fault re-occurs, then you have a leak which you will have to identify
SOURCE: Bosch built in dishwasher shu4302uc
There is a recall on the control board of many of these models. I have written a guide to help. It is here. Look for the phone number near the top.
SOURCE: Bosch SHX33A runs continuously. Never finishes cycle.
I have a guide here to walk you through the process of clearing the drain system. You most likely have a clog somewhere and the dishwasher can't proceed because it would cause it to flood.
SOURCE: Problem with GE Profile Dishwasher
My delay start switch does not work and the dishwasher beeps periodically throughout the day. Also, I have it set for a 109 minute cycle and after about 20 minutes it says that I only have 35 minutes left in the cycle! Any suggestions?
SOURCE: Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Exactly, machine did start properly after being off for a while. Found I could access the pan from the front bottom with a hose. Sucked dry and all set. Thank you. Joe
Your wecome
