My Tv Sinotec LED tv screen is full of lines. Tried everything in the manual what can I do? Tv two month old.
ray gallant
    Top Expert:
  • Televison & ... Master
  • 67,926 Answers
Return it to place of purchase for replacement under warranty
Posted on Nov 01, 2015
5 Related Answers
Anonymous
SOURCE: LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
I unplugged the TV and now the picture is back.I read that the LCD's are vunerable to static build up so unless my daughter is using her TV I unplug it.
I was thinking about getting a large LCD for the family room but I'm not going to until they improve on this technology.
Good luck to everyone!.
Cheers.
Posted on May 08, 2008
crispin melchor
  • 231 Answers
SOURCE: purple line down tv
tv needs repair ..possible bad buffer board or logic board bad and or possibly a bad panel ..
Posted on Mar 18, 2009
Anonymous
  • 10 Answers
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
Posted on May 23, 2009
Anonymous
  • 10 Answers
SOURCE: red vertical line down right side of the screen
hi
I think your TV have a trouble inside lcd panel
the controller board contains driver IC. Deffective driver IC can cause of line display.
Three reasons why one vertical line accross screen can happen in LCD;
1.The missing signal from the controller IC to
LCD driver.
2. LCD driver IC itself defective
3. Dry contact in the tape carrier package.
Use masking or electrical tape to mark it where the line was located. press it if the line back to normal but when release your hand came back i think it was intermittent. Open the LCD panel
Use robber
Place the rubber on the top of TCP
Gently close back the top casing
Good luck...
Posted on Aug 21, 2009
Anonymous
  • 26 Answers
SOURCE: Lines across screen breaking picture into 4 sections
Based on reported problems with Samsung LCD tvs, It is probably one of three problems:
Separation of layers of the LCD panel;
A defective LVDS cable connection;
A defective T-Con circuit board.
If light hand pressure on the affected area on the LCD panel changes the problem, its the defective panel. If not, manipulating the LVDS cable will reveal the cable defect. If not, coolant spray applied to the T-Con circuit board should reveal if it is defective by temporarily alleviating the problem. Dont remove the back cover if you dont know how to protect yourself from electrical shock hazards. There can be more than 1000 volts in the backlight inverter area.
Jerry S
Posted on Feb 11, 2010
I'm looking for the user manual for Sinotec 40inch STL-40E3000 led tv, and also where can I find the manual control buttons on the TV itself
Google (sinotec)(STL-40E3000)(manual) without parens. Once you have the manual in hand you should be able to identify controls and locations.
Aug 07, 2018 | Televison & Video
Horizontal lines on SONY TV
the ribbon flat connection tapes that connect the led panel driver to the panel have prob delaminated
this cant be repaired easily and you would need to replace the panel
Dec 05, 2014 | Sony KDL40EX520 Bravia KDL-40EX520 40 Inch...
No picture on Vizio 60" E601i-A3
yes take it back 6 weeks i would return it
Dec 30, 2012 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Went Wide Screen - how do I get it back to normal?
All TV stations in the US are going digital in the next 11 months, and the format most have adopted is exactly what you describe...accordianman
Feb 27, 2008 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
Televison & Video Logo
483 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
