Question about Frigidaire Microwave Ovens
Need to set clock back one hour - Frigidaire Microwave Ovens
Posted by tanya on
ray gallant
    Top Expert:
  • Frigidaire Master
  • 69,269 Answers
Is there a button that says CLOCK . press it then use number buttons to set the time then press CLOCK again .
Posted on Nov 01, 2015
I just bought whirlpool microwave model wmh32519hz, I can't figure out how to set clock, it has no start button I'm stumped and can't find anything on google
The clock is a 12-hour (12:00-11:59) or 24-hour (0:00-23:59) clock. Touch OPTIONS/CLOCK to reach clock submenu, and follow the prompts to set the clock. Clock format (12 hours with AM and PM, 12 hours without AM
Feb 23, 2018 | Whirlpool Microwave Ovens
Need to set up clock on microwave
go to clock or set press the key enterirng the hour +minute, then press the keys clock or set. and ready.
However you can download your owner manual for instruction.go
www.fitness.manualsonline.com
God bless you
Feb 07, 2013 | Microwave Ovens
Need to st clock on panasonic nne281mm
follow the steps and fix it. God bless you
1) Press the "Stop" button on the microwaveicon1.png to reset the digital display to the clock setting.
2) Push the "Clock" button once. Locate the "Hour" button and press it once for each hour of time. For example, if the current time is 5:15 p.m., press the Hour button five times.
3 )Press the "Minute" button to set the second half of the time. For the example above, you would press the Minute button 15 times to set a time of 5:15 p.m.
4)Push the Clock button to saveicon1.png the time setting. Check the time on the microwave's digital display.
Feb 07, 2013 | Panasonic Microwave Ovens
How to set clock?
You can set the clock to a 12 or 24 hour system.
For 12 hour - Touch clock pad once Enter the time using the number digits (1:00-12:59) Touch clock pad again
For 24 hour - Touch clock pad twice Enter the time using the number digits (0:00-23:59) Touch clock pad again
Mar 05, 2011 | Emerson MW8107WA Microwave Oven
Goes to military time
According to the manual:
Press "Clock" pad once to set clock for 12 hour time clock
and
Press "Clock" pad twice to set the time for Military time.
I'm not sure what you mean by "goes to" military time.
Is that after you've already set it for a 12 hour time clock?
Jul 22, 2010 | Emerson MW8107WA Microwave Oven
Operation manual is lost, how do I set the clock?
The manual for the Magic Chef MCD1311ST Microwave can be downloaded in pdf format from the following site (follow the link then click the "Manuals" tab):
http://www.mcappliance.com/mwodetailpage.aspx?ModelName=MCD1311ST
If you don't have time to download, here's what the instructions state:
SETTING THE CLOCK
When the oven is first plugged in, the display will flash ":0" and a tone will sound. If the AC power ever goes off, the display shows ":0" when the power comes back on.
1. Touch CLOCK pad.
This is a 12 hour clock system.
2. Touch CLOCK pad once more.
This is a 24hour clock system.
NOTE: This oven has multiple clock system. If you want 12 hour clock system, omit this step.
3. Enter the correct time of day by touching the numbers in sequence.
4. Touch CLOCK pad.
The display stops blinking, and the colon start blinking. If you selected 12 hour clock system, this digital clock allows you to set from 1:00 to 12:59. If you selected 24 hour clock system, this digital clock allows you to set from 0:00 to 23:59.
5. Touch STOP/CLEAR pad.
NOTE: If you attempt to enter an incorrect time, the time will not be set and a error signal tone will sound. Touch the CLOCK pad and re-enter the time.
Jun 28, 2010 | Magic Chef MCD1311ST Microwave Oven
How to set clock on sharp microwave
normally you look for the clock ot watch icon. Pressing it once will give you the option for 24 hours setting. Press it twice and it will give you the opportunity to set to 12 hours setting. Using the no. keypad, punch in the time and then repress the clock icon again.
Sep 21, 2009 | Sharp R-1480 Microwave Oven
Jenn-Air clock set for 24-hour
Check the control setup chart on the same page in the middle column.
Press CONTROL SETUP > 3 > 2.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 27, 2008 | Microwave Ovens
Power cuts out after about 5 seconds
Hi try unplugging form mains for an hour this will reset any settings back to factory settings let me know what happens after doing this then i can assist you further ok
Mar 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
I have an Emerson Microwave Oven MW8997W and cannot change the hour (time) on my clock. How do I change the clock? Debbie
If your keys do not work at all, you probably have a bad keypad, in which case I'd ask you to reply back. In the meantime:
SETTING THE CLOCK
When the microwave oven is plugged into an outlet,
the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been set,
the time will appear with blinking colon, unless
the oven is cooking or defrosting.
You can actually download your owner's manual here
Mar 10, 2008 | Microwave Ovens
Microwave Ovens Logo
232 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
