We just had the stove installed. If I get a good fire going, and then close the door, it dies. It acts like the air control damper on the stove isn't working. I have it fully pulled out and the fire dies if I don't have the stove door open a bit.
SOURCE: Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
SOURCE: Fridge gets no air flow, freezer works fine
Air from freezer could also be restricted. Need you to find me the correct model number.
Look at following areas for the model number
SOURCE: replaced alternator, now car won't start
disconnecting the battery on an alternator is a no no. that was how they used to ck generators but an alternator can be damaged with no load in the circuit. Try changing out your MAF sensor. 1st sensor coming out of the air cleaner. good luck.
SOURCE: Remote Control closes garage door but does not open
It sounds like a case of your keypad losing signal strength enough that it cannot transmit through the closed door. If a new battery doesn't do the job a new keypad will.
We have a damper in the chimney pipe. That is working fine. For example, no smoke it coming into the house, it's going out thru the chimney, but it's like no air is getting into the stove itself
look the back of the stove over there may be a lever needs adjusted there
