Question about Magic Audio Players & Recorders
I dropped the mic of my magic sing and now it won't even turn on even with new batteries. My brother tried to open it and he said everything looks fine inside. I don't know what else to do. Help!
Cesar Caldito
    New Friend:
    Problem Solver:
  • 9 Answers
Dropped microphones could disconnect the display/control board from the motherboard. If so, you cannot turn it on using the power button and neither could you see anything on the display. To correct this, you have to open up the unit so as to push the mother board unto the display/control board.
Posted on Aug 30, 2016
5 Related Answers
Anonymous
  • 18 Answers
SOURCE: vocal problem
hi there..if there is video and background audio coming out from the TV, and no voice recognition from the mic- then mic is the problem. I believed the problem is the "voice coil". This is a part that can be replaced- you can contact me and we can repair that.
two ways to check
remove the mic ball
the part which the mic ball is is covering is the voice coil.
try holding both terminals (black and white wire)- if there is feedback sound- it is open and need to be replaced
try using your tester- test the impedance- there should be 500- 600 ohms reading
([email protected] or customerservice @magicmic.com)
Posted on Mar 08, 2009
Anonymous
  • 18 Answers
SOURCE: magic sing
hi i am working in Wow Magic sing- one of the magic sing distributor in Philippines. Is your unit wow , even if its our competitor, the manufacturer is just the same.
kindly give me more detailed information about the model and description. please be more specific.
please try to remove all song chips- if there are any...inverted and dirty song chip wont make the microphone turn ON.
check the cable and cord- open (loose connection) cord or open adaptor will not make it work as well.
Posted on Mar 09, 2009
Anonymous
SOURCE: is there something i can adjust to make it sound better?.. it just does not sound like me.. and it is slow responding to the speakers.. any help would be appreciated thank you
Try this, turn off the mic, then press and hold zero and at the same time power till reboot appear on the screen.
Posted on Aug 05, 2009
Michial Gueffroy
  • 1140 Answers
SOURCE: IT WONT WORK !
This is the support site:http://www.magicsing.com.ph/faq.html#5 Have you tried resetting to the default settings?
Posted on Aug 11, 2009
Anonymous
SOURCE: magic (karaoke) mic sound delay problem when connected to HDTV
Ok..I found a workable solution. Essentially using my HDTV only for the lyrics(video output) and using a RCA to stereo mini plug cable to send the sound output to my amplifier that has a analog stereo input. Works like magic. No delay. It went from being unusable to WOW!
Posted on Aug 28, 2009
4helpful
2answers
3answers
Interference problem on my wireless magic sing, i can hear the voice of my neighbor using her own wireless magic sing on my sound system and vice-versa, it's annoying. what should i do?
The magic sing has an omnidirectional antenna which is unnecessary since you will be standing directly in front of it while using it. I recommend you take an aluminum pie plate or other aluminum piece that is larger than the antenna and place it directly behind it, perhaps even held on by tape to the antenna. You can even bend it around the antenna in the form of a V with the opening towards you, where you'll be holding the mic. This will block the other signals from your neighbor while still allow you to use it. It may even block your signals from leaking onto your neighbor's unit.
2helpful
My magic sing microphone stopped working how do i fix it
my magicsing doesnt switch on, neither with batteries nor with a given power supply
3helpful
IT WONT WORK !
1helpful
Magic sing....i cant hear my voice or anything but all videos and songs are fine help!
you need to replace the voice coil. it is already grounded, that is the one inside the mic ball (where you speak or sing). it is not repairable so you need to purchase a new voice coil
2answers
Indian chips for entertech
hi , jus need to know the following
are your mics still not working ?
how much wud u want for that set
regards
+919820226998
www.magicsingindia.com
3helpful
3answers
Magic sing
3helpful
4answers
Vocal problem
two ways to check
remove the mic ball
Top Magic Audio Players & Recorders Experts
W.L.
ADMIN Andrew
ADMIN Andrew
Tom Chichester
Are you a Magic Audio Player and Recorder Expert? Answer questions, earn points and help others
