Behringer PMP1000 Europower Powered Mixer Logo
W
Wayne Blalock Posted on Oct 30, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to get output from the back speak-on connections
Steve
Level 3:
  • Behringer Master 3,290 Answers
  • Posted on Oct 31, 2015
Steve
Behringer Master
Level 3:
Answers
3290
Questions
Helped
1126956
Points
12184
I'm new to the oh thing. I bought a Peavey XR684F powered mixer. There are 4 output jacks on the back for speakers. Which ones do I use? I have 2 Behringer B215XL speakers. I also want to use a floor...
Connect the two Behringer B215XL to the Right/Main Speaker Outputs. Monitor(s) would connect to the Left/Mon Speaker Outputs
manual is here: https://assets.peavey.com/literature/manuals/xr684fand696f_manual.pdf
tip
How to Set up Auxiliaries on a Mixer.
Here are some tips to set up the auxiliaries properly on your mixer:
  • Step1:
Your auxiliaries allow you to send the signal from a channel strip to somewhere else while maintaining the signal on the channel strip. For instance, you can use auxiliaries for monitor mixes for performers in a live environment. You can also use auxiliaries for external effects processors or a number of different situations.
  • Step2:
Set the auxiliaries to pre-fader to allow you to change the level for the auxiliary with the auxiliary knob but not with the channel fader. Most mixers have a "Pre" button that allows you to enable pre-fader mode. If you don't have the button pressed, your auxiliaries are in post-fader mode, which means your channel fader will affect the signal level of the auxiliary output. For monitor mixes, you usually want to use pre-fader so you can control monitor mixes independently from the front of house mix. Some effects processors will be better to run post-fader, though, so don't always rely on pre-fader.
  • Step3:
Send out your auxiliary sends. On the back of your board, you there are the auxiliary outputs. For a monitor mix, you will use these outputs to connect to the inputs of the monitors. When using an effects processor, you will use the auxiliary output to connect to the input of the effects processor.
  • Step4:
Plug in a return if necessary. If you are just doing monitors, you do not need returns to the mixer. When using effects processors though, you need a way to get your effected signal back to your mixer. Take the output of the effects processor and connect that to the return input on the back of the mixer. Now you will have to adjust the return section on your channel strip to get the desired signal.
  • Step5:
Use the auxiliary knob to set the desired level. Once you know if you are running pre- or post-fader, and you have your inputs and outputs all correct, you can start sending signal to your auxiliary output. Turn up the auxiliary knob until either your monitors are set correctly or until you have the desired amount of signal going to your effects processor or other outboard equipment.
2answers
How do I hook up the speakes with 1 main main and one main monitor?
Need more info, how many main speakers and monitor speakers are you trying to plug into the unit?
No sound and peak is on all the time
Remember...it's a process of elimination when troubleshooting any thing. Have you tried another dynamic mic that does NOT need phantom power to operate? Connect your MP3 player to the Line In 1/4" connection and see if the sound passes to the output. Other than buying a replacement power supply, these units are not economical to repair...as I'm writing they sell for $70 new online.
Hi i have an Allen and Heath ZED 22 with no onboard effects. I would like to use an external Behringher unit but am having difficulty in connecting the processed signal back to the mixer. i would like to...
Send audio from board via the "Aux1 Out" to the input of the effects unit. Now connect the output of the effects unit to "ST1" and control the amount of effects to each channel via each channels "Aux1" control. Adjust the Aux1 controls in the output stage (controls on the right side) for proper levels.
Older boards called this connection "effects send" for the output to the effect, and "effects return" for the effects out back to the board. The better choice was to use "effects send" into the effect but connect the effects output to an unused channel on the board. Using this scenario allowed EQ adjustments to be made before mixing it out to the amps and speakers.
How to connect floor monitor to mixer
You need to connect the speakers using an XLR cable into the Main output jack on the back of the mixer. If they are powered speakers you will need to connect them into a power source and turn them on AFTER connecting them. Once powered on you can control the signal going to the mixer with the Main Mix fader.
  1. Turn mixer on
  2. Ensure Main Mix level is at zero
  3. Connect from Main Output to Monitors
  4. Turn Monitors on
  5. Turn up Main mix to desired level
Can i connect the pv 112 to the pv 118 subwoofer since the powered mixer i bought it only has 2 main outputs? The powered mixer I bought is the PV XR 8600D powered mixer...
Generally speaking you should only send low frequencies to subs. The highs, while lower in power than the lows, will over time harm the voice coils. The ideal way to do this is to use an external crossover netween the main output and the amp input with the higher range going to a general set of speakers. Send the lows through the second channel of the amp and then to the subs.
In short, while not recommended, yes you can hook them up in parallel.
Dan
3helpful
3answers
How do i connect yamaha mixer to pc or yamaha receiver
I am sorry to disagree, but some information in the previous post is INCORRECT. DO NOT connect the output of the mixer to the MIC input. The mixer generates LINE level output that should go to the LINE-IN on the sound card. If you connect the mixer to the mic input, you will damage the sound card. MIC level inputs have an additional amplification stage.
Dan
1helpful
2answers
Just bought a new Tascam 2488 portastudio. Following directions to record first song, but I can't get sound through either headphones or monitor outputs. I know I have a signal because I can overdrive it...
Read page 19 under Monitor section.You have to assign the signal to the monitor output you want. Page 36 has the details. All the info you need is here with some updates:http://www.korg.com/product.aspx?pd=191
Top Behringer Music Experts
john h
Are you a Behringer Music Expert? Answer questions, earn points and help others
