SOURCE: Kenmore Elite Dishwasher
I have the same problem...did you ever get an answer on how to repair
SOURCE: my carlton dishwasher fill and drains but does not wash
sounds as though the wash motor/pump is jammed or has seized therefore no wash.
SOURCE: Humming noise after water fill and will not wash
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
SOURCE: Hum in Kitchen Aid Dishwasher Model 8531529.
Hi The hum sound that you hear is from the motor that is not
working or is about to go out, the motor should be replaced. Hope this
helps...please post back for further assistance. Daniel
SOURCE: My kenmore elite dishwasher 665.17053400 motor
The motor may be siezed, or there may be something in the impeller that is keeping the motor from turning.
The only way to know for sure is to remove the motor unit and visually inspect it.
If you cannot manually move the impeller or if it is very difficult to turn, then you will need to replace the motor unit assembly.
Its costly $155.36 plus shipping at www.searspartsdirect.com
But if the motor is bad then the motor is bad.
Just curious, how old is the dishwasher?
