Copystar CS-2114 Copier Logo
Darlene Quinlan Posted on Oct 30, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Copier is coping to dark on the sides even when it is set at the lightest setting
I tried cleaning the mirrors
Mike Lyste
Level 2:
Champion:
  • Copystar Expert 250 Answers
  • Posted on Jul 12, 2017
Mike Lyste
Copystar Expert
Level 2:
Champion:
Answers
250
Questions
Helped
200673
Points
346
Needs new drum unit
I have a Canon NP6230 copier that I am having trouble with.
I beliwe I allready answered that question too, a while ago,but anyway...You has to clean plattenglass,optical system and mirrors.How many copies did drum made? If more than 100000 you'll probably got to change it
Copies are too dark, even with the Automatic button turned off and the exposure set to lightest.
Hi which model are you talking about?
These is problem with analogue copiers like NP1550/6216/6030,...
Where these means that You need to clean optics, lenses because of dirt on them which is shown as dark copies.
Hope that helps!
Minolta cs pro EP3000 copier. The copy is too dark even on lightest.thanks
Clean the optical parts:mirrors,lens and the charge and transfer/sepaRATOR CORONAS.
1helpful
Copier prints dark on lightest setting
this could be down to several thisngs lift the lid on the top and look at the glass area does the underside look clean or dirty? have a look at the scanner area to see if there is dust ont the mirrors you should see this when you do a test copy press the print button and look at the light unit and the mirrors as they move across the glass if you can see dust or dirt on the mirrors they may require cleaning.. if so turn the machine off take out the screws holding the glass in place lift the glass out carefully.. sometimes they stick down if they havent been cleaned lately so pull up.. take a clean dust cloth slide the scanner unit out for access and clean of the mirrors.. p[ut back together and test if no better open the fornt door and look at the units inside to see if you can take them out..give these a check to see if there are marks on the surfaces of the units.. if the copies are dark usually on a old copier its down to the dust..
1helpful
Cannon PC1061 making dark copies
OR you can do it yourself.
your problems seems to be Dirty Mirrors.
Your copiear has 6 mirrors that need to be clean up. 5 of them are kinda easy access. the other needs to be clean thru something thiner than your fingers. (you can see the mirror but no way you can reach it).
Now dont worry (not yet) about that 6th mirror since THEORICALLY it doesnt get dirty.
So try first to clean up the other mirrors. and see what happens.
They are located below the platen glass (remove it) and be careful with the lenses (do not touch them). clean everything that seems to reflect light Or images.
If nothing changes you may want to try out with a new cartdrige. Your drum may be done.
Copies have gray background.
Have you had the optics cleaned resently? If not Iwould start with that and make sure you have the copier unpluged and don't forget to clean the two mirrors under the Black Box/cover. It could also,mean that you need a new OPC drum and blade.. It depends on how maiy copies are on the copier and drum...
2helpful
2answers
Canon 6025
Your problem is most likely caused by dirty optics. Place a sheet of paper on the glass & make 1 copy with the lid up. Look under the glass at the mirrors on the scanner & see if there is any dust on them. If so,turn the copier off & unplug it from the wall, remove the glass & wipe off the mirrors with a DRY cotton rag. There are 3 mirrors on the scanner assy. There is also three mirrors under the lens cover that should also be cleaned. After cleaning the optics, make a test copy.If your copies are still to dark, press the additional functions key & select exposure adjustment. You can lighten/darken all copies by changing this setting. If you have any problems or questions my email is [email protected] Good Luck!!
Top Copystar Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
