You can try finding your answer in user manual Dyson Dc07 Manual Download Free Manuals
You're a bit unclear on what screws you took apart to 'clean it'. If you took the canister apart, then this Snapguide page
How to Clean Dyson DC07 Canister goes through taking the top section thoroughly apart, and has some notes about things needing to line back up properly, which might help in the event that you're not getting things to snap back together right. I took mine apart solo after picking it up cheap at a flea market, and also recall reassembling the top took a little patience.
Good Luck!
SOURCE: I would like to clean my Dyson DCO7. I have lost
Here is a link to a manual you can view:
Dyson DC07 Manual
SOURCE: hi, i took apart filters to clean in my dyson dc25
Hi its Darran at Dyson.
It may be worth taking the filter in the ball out and putting it back making sure it has clicked back into place securely.
If you need advice on this, please visit our website at www.dyson.com and click on the support section.
Alternatively, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Testimonial: "I went to the dyson website...and figured it out thru pictures. Thank you!"
SOURCE: I cleaned out my dyson ball as it smelt when i
The screws on the base of the cleaner head should not have to be removed to access the brush bar so it is possible that the brush bar has come out of alignment, hence the noise the machnie is making.
Please ensure that the soleplate has been correctly positioned and that the brush bar is aligned correctly before attempting to use the machine.
If this does not resolve the problem, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
SOURCE: i opened my dc17 dyson to clean teh motor. trying
I'm not sure about all the switches used in the vacuum, but I recently took some pictures of the power button assembly. The buttons in the picture below are (from left-to-right): Circuit Breaker, Brush Switch, Power Switch
The next picture shows how the plastic buttons that operate the brush and power switches should go together:
And finally, this is how the power button assembly reattaches:
SOURCE: I have a dyson canister
sounds like your belt is worned out its not gripping i suggest change belt have it replaced
