Question about NorStar T7316E Corded Phone
I want to change the names assigned to our phones.
I know I have to enter Feature **266344 but when I enter Feature * it doesn't let me enter the second * so I can't put the code in?
Posted by Nancy on
5 Related Answers
mark hudson
  • 326 Answers
SOURCE: Changing Time and Date
i had this problem a while ago, you have to set the time from the main phone
Press FEATURE **8463 – Display shows PASSWORD:
Then type in 23646 (Note this number will not show on display)
The display will show hours.
Press CHANGE (or NEXT if you do not need to change the hour).
Enter the hour (00 to 23). If number is less than 13, the display shows AM.
Press CHANGE to select PM.
Press NEXT. The display shows minutes.
Press CHANGE (or NEXT if you do not need to change the minutes).
Enter the minutes (00 to 59).
Press NEXT. The display shows year.
Press CHANGE (or NEXT if you do not need to change the year).
Enter the last two digits of current year.
Press NEXT. The display shows month.
Press CHANGE (or NEXT if you do not need to change the month).
Enter the month (01 to 12).
Press NEXT. The display shows day.
Press CHANGE.
Enter the day of the month (10 to 31)
Press RLS (release) to exit.
Posted on Apr 18, 2008
Anonymous
SOURCE: name change on norstar system
try 266344 as the password
Posted on Aug 14, 2008
Anonymous
SOURCE: How do I program the Call Log feature to display
http://www.telephonemagic.com/phone-support/norstar-feature-programming-code.htm
go to this website
Posted on Nov 19, 2008
Anonymous
SOURCE: Display Names
Hi....go to www.phonserv.com and you will find the answers to just about all your questions for this phone....I could send you a copy of mine if you like just send me your email or go to the site yourself and print one...its very handy....
Posted on Nov 24, 2008
consultel1
george peters
  • 860 Answers
SOURCE: Log in to system programming T7316E
the log should be "setnna"(738662) with a password of config (266344) providing it hasn't been changed
Posted on Mar 30, 2009
When I enter feature code **266344 I get RELEASE CALLS. What has happened. The feature worked before.
Hang up any calls active or on hold first. Cannot enter CONFIG mode during a call, or with a held call.
Aug 27, 2014 | NorStar T7316E Corded Phone
We need help with our Nortel system (T7316E). We don't know the admin password. We have tried Feature 985 and then it says to hit "9" but we can't do that as the display shows VM:363 and we can only hit...
feature 985 shows you your vm extension #.
feature 983 then try 1029999 (if password was changed to 9999 or something else)
or maybe feature 983 then 738662 'ok' then 266344 'ok'. depending on the norstar system you have.
these are some codes to enter the vm management. What are you trying to do, reset a vm password or other system programming?
Apr 17, 2014 | NorStar T7316E Corded Phone
**feature 266344 nothing happens just seeing release call need to change my display name
It usually says release call if you have the handset up, a call on hold, or if your telephone is ringing. If the set is idle and with the handset down enter in feature **266344.
Sep 29, 2010 | NorStar M7324 Telephone
Codes
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number.
Enter extension number you want to change to handsfree.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
Press the show key (top right arrow) .
The display say foward no answer.
press the next key 3 times (bottom right arrow)..
The display should say handsfree. Press the show key.(top right arrow) change from none to auto
Press the release key when finished
May 26, 2010 | NorStar M7310 Corded Phone
How do I set up a phone to display caller id? It displays on other phones in the office but not on mine.
To set up call id you need to enter programming2.gif . Programming is done on M7310, M7324, and T7316 sets only. Press the feature key followed by **266344.When prompted to enter the password enter 266344.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program call log on. Press the show key (top right arrow)
Press the next key (bottom right arrow) 5 times. The display should say TELCO FEATURES.
Press the show key (top right arrow) 2 times. The display should say CALLED ID: N(or Y)Press the change key til it says Y.
press the release key.
May 03, 2010 | NorStar T7316E Telephone
How to change the time and date on nortel phone
Programming2.gif is done on 7310, 7324 and 7316 type sets.
The screen should say A. Configuration. The 4 top line/feature keys are now used for programming.
Press "NEXT"(bottom right arrow)
display should read B.General Administration.
display should read 1.speed dial
Press the next key 2 times(bottom right arrow) .
display should say 3.time and date
display should show current programmed time
Press the Change key
Enter in time in 12 hour format
press ok
press either Am or PM when prompted
press ok
press the Rls key when finished
Nov 04, 2009 | NorStar T7316E Corded Phone
Trying to change the intercom caller ID onthe M7324
The display should now ask for an extension number. Enter extension number you want to change the name on.
The display say Name.
press the Chng soft key.
use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
ex. Bill = 2,2 -> 4,4,4 -> 5,5,5 -> 5,5,5
Press the next key (bottom right arrow) to enter the name.
Oct 23, 2009 | NorStar Meridian M7310 Phone
THE PHONE FLASHES BUT DOES NOT RING? We had a power cut the other day and since the phones have not rung, just flash? Anyone know why? We have 3 lines coming into the building. The lines have all been...
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The 4 top line/feature keys are now used for programming2.gif.
The display should now ask for an extension number. Enter extension number you wish to program ringing on.
The display should sat LINE ACCESS
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear only
press the Chng key till it says appear & ring
press next key (lower right arrow)The display should say line 002: appear only
repeat procedure for remailing active lines
If your system uses the older programming template,
then Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
the display says A. Configuration
the display will say1. trunk/line data
the display will say 2.line access
the display will say line assignment
The display should say ringing.
Press the show key (top right arrow).
the lines should be listed as appear only change to appear and ring
press Rls when finished
Oct 23, 2009 | NorStar M7208 Corded Phone
One of our office Norstar 7310 phones was unhooked and when it was plugged back in the phone extension no longer works. The extension needs to be reset but no one knows the administration password - I've...
The password you need is cnfig 266344 So you enter feature ** 266344 password 266344 this will get you in now go to maintenace and reset the phone its probably oos
Mar 06, 2009 | NorStar M7310 Corded Phone
Nortel Norstar T7316E phone programming
feature 983 it will ask for log number use code 120000 for 2 number extensions, for 3 letter extensions it is 1020000, and 4 is 10020000 once in this screen hit MBOX then CHNG and put in mail box number then hit next until you get to the name and press CHNG and you can change it using the the number corresponding to the letter I hope this helps
Feb 28, 2008 | Lands Phones
NorStar T7316E Corded Phone Logo
196 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
pbxinc
martin hogg
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
