Question about Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
How do I unlock a whirlpool oven - Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
Posted by herberttrice on
Can not unlock oven door on whirlpool gas range
Hi try holding the clear button for three second's , alsocould unplug the 120 volt for a few min's and then plug it back in , let me know if this works
Dec 06, 2011 | Whirlpool Ovens
I have a whirlpool self cleaning oven, the door locked when cleaning and will not unlock when cooled down
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Nov 07, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
How do you unlock a whirlpool stove if it locks manual
I think you mean if it locks automatically not "manual". There should be small print next to one of the buttons that includes the word "lock". Hold this button down until the indicator goes out.
Aug 08, 2009 | Whirlpool RBS245PDS Electric Single Oven
Whirlpool Gold oven is locked
Had to switch it off at the breaker, wait for it to cool down, and switch the breaker back on. Then it unlocked. In the meantime, however, our french fries were completely incinerated, and the house filled with smoke.
Jul 28, 2009 | Whirlpool SB160PEE Gas Single Oven
How to unlock a whirlpool gold oven..i can open it..i cant start the oven to bae anything because it says its lock..i dnt know what to do.
You will have to replace the defective door latch switch. It is sending a false signal. Check with a Whirlpool authorized repair shop. Some of these were on a recall list.
Jul 14, 2009 | Whirlpool SB160PEE Gas Single Oven
Stove won't unlock
some of the kenmores have the door lock motors in the back behind the large panel slide out an remove panel an pull or push the rod to unlock door if motor is bad for a temp fix just remove rod
Aug 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven wont work after self clean
I have a Whirlpool MOD. RBS275PDB17 single electric self-cleaning oven; although the manual is generic, it specifies, "When the cycle is completed and the oven cools, "End" will appear on the lower oven display and "LOCKED' will disappear" and "To Stop Self-Clean any time: Press UPPER/OFF, LOWER/OFF or OFF/CANCEL. If the oven temperature is too high, the door will remain locked. It will not unlock until the oven cools." Has your oven had time to cool?
Jun 13, 2008 | Whirlpool RBS275PD Electric Single Oven
My self cleaning oven will not unlock
i would try to set fro a clen clycle again, it should try to relock the door and then simply cancel cycle and should reset. or try turning off breaker, upon restoring power it should check the door latch mechinism and unlock
May 11, 2008 | Whirlpool RBS275PD Electric Single Oven
Problem with our oven
how to fit a heating eliment to a whirlpool akz451/1x/01 oven please
Feb 24, 2008 | Whirlpool RBS275PD Electric Single Oven
Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
