Where is the thermostat located on the Hotpoint fridge/freezer RSAV21
Posted by Paul Morris on
Claude Kayser
    Top Expert:
  • 9,098 Answers
Basic Fridge Repair & Maintenance - Hotpoint Fridge Freezer
? 3:27
www.youtube.com/watch?v=YPglk963cXM
Sep 7, 2012 - Uploaded by Ezee-Fix Basic Fridge Repair & Maintenance - Hotpoint Fridge Freezer. Ezee-Fix .... Refrigerator Repair- Replacing ...Missing: rsav21
Free Hotpoint Refrigerator User Manuals ' ManualsOnline.com
kitchen.manualsonline.com > ... > Hotpoint > Kitchen Appliance Hotpoin
Products 1 - 50 of 299 - Hotpoint Top-Freezer Refrigerators Owner's Manual and Installation Instructions 18, 19 .... Hotpoint BL31 Larder Fridge Instructions for Use.
Posted on Oct 29, 2015
Where is the thermostat in a hotpoint ffa97 fridge freezer
The sites enclosed will have parts diagrams and locations for your.
Sep 23, 2017 | Hotpoint Refrigerators
Where is thermastat on hotpoint fridge freezer RSAV21 model
Of the two controls within the refrigerator compartment, USUALLY the one for the refrigerator is nothing but a plastic flapper type damper in a duct that is routed from the freezer compartment to the refrigerator compartment. There are no wires attached to it.
The actual thermostat USUALLY is in the same compartment but has a sensing bulb that extends up into the freezer compartment or at least very near to entering the freezer compartment. It WILL have wires on it. Yours may be located in the center, top rear of the refrigerator.
Oct 29, 2015 | Heating & Cooling
Hotpoint RLA64T fridge freezing up after new thermostat fitted
WHEN U TALK ABOUT THE THERMOSTAT U MEAN THE COLD CONTROL THERMOSTAT OR DEFROST TIMER THERMOSTAT? WHEN UR PROBLEM SOUNDS MORE LIKE THE DEFROST TERMINATOR OR BAD HEATING ELEMENT, LOCATED ON THE FREEZER EVAPORATOR COILS? IF ITS STAYING ON ALL THE TIME U HAVE A DEFROST ISSUE? OR BAD SEALS ON DOOR AND DIRTY COMPRESSOR
Aug 02, 2014 | Hotpoint Refrigerators
WHERE IS THE THERMOSTAT ON HOTPOINT FRIDGE FFA60
i have a hot point,side by side,little old but great fridge.It is located where adjustments are you can hear it click when you turn it up or down but their is a element in freezer like a big fuse that gets hot and defrosts the coils behind the plastic in freezer.if it is out it will cause unit to freeze up and it will not cool properly.I replaced mine and man what a difference.At first icecream would sometimes be ok then not.if you turn fridge down for while then turn it back up and hear a click then it starts to run its the element in freezer
May 25, 2012 | Hotpoint Refrigerators
Myfreezer works fine but my fridge only works for about 15 days and then stops working,when i unplug the fridge and let it defrost the freezer will work for another 15 days it is a hotpoint ff4dx fridge...
This is telling you that you have an automatic defrost problem.
Before I go on here the model number you passed appears to be a UK model.
The problem can be:
1. The defrost timer / control
2. The 60 deg F defrost bi-metal thermostat
3. Wiring
4. The defrost element.
Some info about the 5 year warranty is on page 11 of the owners manual: http://www.hotpoint.co.uk/hotpoint/_pdf/manuals/19506810502_UK.pdf
I do not locate the appliance parts manual for this unit as I am not in the UK.
Thanks for using FixYa.
Kelly
Jun 16, 2010 | Refrigerators
I have a hotpoint fridge which keeps freezing up i have changed the thermostat but it as not cured the problem
Defroster cycle is bad. Located in the space between fridge and freezer. Depending on the model the area where this defroster is located can be accessed through the bottom of the freezer by removing the bottom panel of the freezer. It will more than likely be a long tube looking device and can be purchased at an appliance parts store.
Dave
Jan 08, 2010 | Refrigerators
Hotpoint RFA52 fridge freezer
if you cant hear the motor/compressor running when energised then its likely to be a thermostat fault... but on energising the system if you hear a buzz then a click then its more seriously the main motor... turn off at mains for 5 mins then turn on... this should tell you either way
Dec 22, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint fridge freezer icing up freezer and fridge does not work
Does your model have independent thermostats for the fridge & freezer???
If not, could be that you will need to change the Thermostat.
These are not expensive - around £10 if you buy on the Internet.
Easy to fit yourself...just turn off the power, remove the power plug from the wall, then unscrew the 'stat unit from inside near the top of the fridge (some are attached to the interior light) and remove the screw holding the thermostat tube to the rear wall.
Often the thermostat gets a small hole somewhere in the long tube, which then lets all the gas escape, making the stat useless.
You can see these small holes in the pipe if you use a magnifying eyeglass, like the kind Jewellers use.
Nov 17, 2009 | Freezers
Sid By Side Freezer Icing and Fridge not Cold
most fridges in s.a the defrosting is done by the thermostat if the fridge does not have a pc board
Jun 16, 2009 | Hotpoint 21.7 cu. ft. Side-by-Side...
Heating & Cooling Logo
395 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
