Toshiba 56HM195 DLP Flickering Problem - YouTube
? 0:08
www.youtube.com/watch?v=SxnUYXkaLr4
Nov 21, 2009 - Uploaded by Brian Baute
Flickering & green boxes appearing all over my Toshiba56HM195 screen. This behavior is consistent all the time, with multiple lamps, and across multiple inp... ... Up next. Stay Away From Toshiba DLP Projection Television!
SOURCE: Toshiba projection TV Flickers
You may have bad convergence chips in the set. I have worked on some with similar problems and replacing the convergence chips was the solution. Good luck and I hope this has helped.
Ed
NC Electronic
Mills, Wyoming
SOURCE: color problems with Hitachi 57in rear projection
One or more of the projectors lights( my guess is the green one) are either blown or in the process of going bad. Have them repaired or replqaced by an authorized tech.
SOURCE: the tv seems really dark.57in theatrewide hd toshiba
Go into the tv menu and select the Preferences menu and set your picutre preference from Theater to Normal. The TV is currently in Theater mode, wich is for viewing with no lights on in the room. Switching it to normal lightens the pictue a lot.
SOURCE: my toshiba 57in rear projection the color is off
Sounds like you need to check the convergence. You can in the MENU under PICTURE go down to the CONVERGENCE to make the adjustment, set the RED and BLUE
SOURCE: i have lines on the bottom of my 57in rear
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
You can get a repair kit with parts and instructions from www.TvRepairKits.com
