Question about Lexmark X Office Equipment & Supplies
I have a956.02 error processor fan stalled. how do I fixed it
Posted by terry cahill on
MY computer shuts itself off and then restarts, about once a day
You will need to check your event log in order to pin point where it is shutting down, thus solving the problem as it could be any number of things.
Dec 31, 2013 | Compaq Computers & Internet
Fan slow down and them high speed
change the fan ASAP, since the zooming noise and the slow performance will affect even the processor and you might end up replacing the processor as well if it persists. So get the fan ASAP and problem will be solved.
Sep 30, 2013 | Gateway GT5622 PC Desktop
Overheating issues with laptop
Following are the reasons for overheating, just take care of these things::
Stop Overclocking your CPU
Make sure your Heat Sink is placed properly above the processor
Clean the Processor fan, Heat Sink and other peripherals
Use High Speed fans
Use CPU Heat Sink Paste in the processor
Make sure your dint restrict the speed of CPU fan.
Use proper ventilation in your room
Shut down your computer at least two hour a day
If it didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of overheating
Sep 23, 2013 | Toshiba Satellite Computers & Internet
Fan dose not slow down
It seems that your system is overheating so follow these instructions first
- Make sure your Heat Sink is placed properly above the processor
- Clean the Processor fan, Heat Sink and other peripherals
- Use High Speed fans
- Use CPU Heat Sink Paste in the processor
- Make sure your dint restrict the speed of CPU fan
- Shut down your computer atleast two hour a day
If you are unable to perform above tasks then use a single utility tool like PC Fresher that will fix windows errors that cause of overheating
Aug 27, 2013 | HP TouchSmart Computers & Internet
Laptop lgr40
1. Stop Overclocking your CPU
2. Make sure your Heat Sink is placed properly above the processor
3. Clean the Processor fan, Heat Sink and other peripherals
4. Use High Speed fans
5. Use CPU Heat Sink Paste in the processor
6. Make sure your dint restrict the speed of CPU fan.
7. Use Additional Cooling Units
8. Check your SMPS
9. Use proper ventilation in your room
10. Shut down your computer at least two hour a day
Let me know if it helps you.
Use system utility tool like RegInOut to remove unwanted files , fix registry and windows errors which cause of heat problems
Jul 03, 2013 | Computers & Internet
Pc suddenly powers off
that can be meaning if the processor is Not Supported with your motherboard,or the New Processor is not in good condition (can be Over Heat or damage).
Processor over heat or damage can be because the HEAT SINK (white or grey pasta at the top of processor) is not enaugh to cooling the processor or,the fan Proseccor is Dirty.
Jan 18, 2012 | Computers & Internet
CPU Over Temperature Error
Hello
This error mostly comes with the failure of processor fan, overheating of processor shuts down the system due to processor's protection. You need to check the fans and replacement is recommended.
Hope this helps
Jan 31, 2011 | ASUS P5PE-VM Motherboard
CPU Running Fan not recognized by motherboard M7VIG 400
Check out
1.the heat sinker is tightly fixed on the processor.
2.check and clean the dust in the processor ad the coolingflood on top of the processor
Jun 30, 2010 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
Coprocessor error ! who do i fix this?
could be you have a faulty processor on your system or for some reason is failing when an operation was forwarded for the processor to execute and it failed to do it.
1. check your processor fans
2. if you were overclocking go into your bios/cmos program and set everything back.
http://www.pctoday.com/techsupport/detail.aspx?guid=&ErrorID=23340
Sep 30, 2008 | Computers & Internet
Processor fan
Maybe you have not put the correct fan on and it has shut down to protect itself. Processors overhead catastrophically in a matter of seconds. Also did you connect the fan to a power supply on the motherboard.
Mar 18, 2008 | Intel (SL5TL) Pentium 4, 2 GHz Processor
59 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
