Magnavox 32ME303V/F7 32" LED TV 1366x768, 60 Hz, HDTV Logo
Jessica Scrappy Phillips Posted on Oct 29, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The volume goes down as if someone is pressing button. how can i fix it?
Level 3:
Top Expert:
  • Magnavox Master 76,851 Answers
  • Posted on Oct 29, 2015
Magnavox Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15006833
Points
237762
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
2answers
How to factory reset my ZTE Z3001S?
Google search found this ..
  1. Back up data on the internal memory.
  2. Turn off the device.
  3. Press and hold the Volume Up and Power buttons until the ZTE logo screen appears, then release.
  4. Press the Volume down button to highlight wipe data/factory reset.
  5. Press the Power button to select.
  6. Press the Volume down button repeatedly until Yes -- delete all user data is highlighted.
  7. Press the Power button to select.
  8. Wait as the device resets.
  9. Once complete, press the Power button to select Reboot system now.
1helpful
How do I factory or hard reset my digiland model No. Dl8006 tablet
hard reset
hold down the power button and the volume down button at the same time till the chinese writing comes on
then go down with the volume down button to the 6 menu = 3rd from bottom press the power button to ok it
then it will reset
if its in english do the first bit hold down power button and volume down button at the same time till the android man with writing comes on
go down to wipe data withe the volume down button highlight that press the power button to ok it
then go down to yes with the volume down button highlight yes press power button to ok it then it will reset
then if it goes back to the writing go to reboot highlight that press power button to ok it
factory reset settings go down to back up and reset click on
go to reset
then it will reset
1helpful
2answers
I have my brothers droid moto phone he passed away and I want to get it hooked up to Verizon but do not know his password. How can I clean the old password off of the phone and install my password.
Hi @Rock Aduh , are we talking about the password to go in to the phone? If it is, please perform a factory reset.
1. Ensure the device is powered off.
Note If the device doesn't respond to input, press and hold the Volume Up/Down button then press and hold the Power button. When the device screen goes blank, release the Power button while continuing to hold the Volume Up/Down button then proceed with step 3.
2. Press and hold the Volume Up/Down buttons then press the Power button.
Note When presented with the Boot Mode Selection Menu, release all buttons.
3. Press the Volume Down button to tap Recovery then press the Volume Up button.
4. From the DROID triage screen:
a. Press and hold the Volume Down button.
b. Press and release the Volume Up button.
c. Release the Volume Down button.
5. Select wipe data or Factory Reset.
Note Utilize the volume keys to highlight and the Power button to select.
7. Select Yes -- delete all user data.
Note Data wipe may take several moments.
8. Select reboot system now.
Note To set up the device after the reset has completed, refer to Initial Activation and Set up.
Hope this helps. Factory Data Reset Powered Off DROID RAZR RAZR MAXX by MOTOROLA
Cannot turn the tablet on
Press and hold down the on/off button for 40 seconds and then press it again. See if that unlocks it.
How to reset MID 7 inch Android 2.2 VIA8650 ePad Tabllet
try this:
1.Power the device is OFF
2.Press n Hold the volume DOWN Button
3.Press and hold the power button for 5secs
4. Release the power button WHILE still holding the Volume down Button
5.When the logo appears release the Volume Button
6. Use the Volume Up/Down buttons to highlight Factory Reset
7. Press Power Button to select
allow the process to run...the device will restart as normal (should restart as normal if all goes as planned)
Volume keeps going down on samsung t260hd
The digital main board has the fault. This is not a user repairable one. Contact any technician.
Magnavox 32mf369b/f7 sound occasionally decreases by itself, as if someone pressed the button
The volume button must be smashed in,dirty,or defective...I would try pressing the volume- several times repeatedly..maybe try cleaning it with a can of air.
When I press the up volume button on the remote it goes up but continues without my pressing anything and it also does the same thing when i press the down button the volume goes all the way down. However...
There's a good chance the batteries are just low in the remote. Replace them and see if that fixes the issue.
Also make sure there isn't direct sunlight hitting the infra-red receiver on the TV.
Controls
Someone push the volume up button too hard and is stuck,this also has the micro(brain) confused,all this happen before you fund out your remote would not work.
Top Magnavox Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
