This is an older RCA console color tv which works well but need to get sound issue repaired. Does anyone in Toledo Ohio area still fix these?
SOURCE: Buzzing sound by bulb
be quite sure that it is not the fan physically touching the case; other than that, scope your B+ voltage to the ballast and be certain it is clean; while it could be that or the lamp itself, it is most probably loose or misaligned case assembley
SOURCE: RCA RT2500 Buzzing Sound - Replace 6800uv 16v caps
I did it. I decided to go ahead with the repair myself. I have never done something like this before but it was easier than I thought. I filed off the old parts and soldered on the new. It works like a charm. Thanks.
SOURCE: rca hd52w59 making a high pitch buzzing sound
is this just a whine since you describe no problem with the picture it dosent jump or change color or flicker. there may be an easy fix this sounds like some coils oscillating and i tell you what can be done you can take some silcon and put on these coils to dampen then vibrations. now ther may be other problems but without looking this is my first gues ...where are these coils? ll037 on the power supply deflection board
SOURCE: TV has no sound
First try resetting by unplugging totally from the AC, then reconnect and try again. if still no audio, check all inputs to make sure its not a bad cable/sat box , next check for a speaker switch either on the back of the Tv or in the menu. make sure the cable box and TV is not in SAP second audio program mode. if these all fail then you make need the audio IC replaced on the main board
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
SOURCE: When playing Lego Harry Potter for the Wii the
It is a game issue fortunately. I thought there was something wrong with my Wii as well, but after reading tons of forum posts across the internet on many sites from people with the exact same problem, even with new consoles, the answer was clear.
This game has freezing problems for all versions, not just Wii. Unfortunately, I'm pretty sure the Wii can't download patches for its games, unlike the 360, PC, and PS3, So I have no idea how they are gonna solve this problem. Maybe recall the game and re-issue it?
Anyways, If other games work fine, your Wii is alright. If other games do not work all the time, or also freeze up on you, get a Wii Lens Cleaning Kit. I got one off of Amazon.com for super cheap (around 10 bucks), and it works like a dream, my console ran like new again. Hope this helps others who are concerned about this issue.
Buy Wii Lens Cleaning Kit on Amazon.com
