Question about Measuring Tools & Sensors
I can't get the weather part to work. I've tried resetting. Chris
Posted by Christie Ryan on
Andrew Taylor
    Top Expert:
  • 33,457 Answers
This is how mine works. Remove the battery from the inside unit and the outside sender. Put the battery into the indoor unit and then put the battery into the sender unit.
Posted on Oct 28, 2015
Digitech weather station rain not reading
Remove the cover and check is a spider has built a web over the
tilt bucket. I have to clear mine ona regular basis.
If this is a proglem, spray the inside if the cover with a surfase spray.
Apr 20, 2012 | Digi Measuring Tools & Sensors
I have a PT 56DLX25 Panasonic hd projection tv that has a dim picture and we just put in a new bulb
Have you tried to do a system reset after installing the new bulb? I'd also check all of the visual settings, now that you've replaced the bulb, the settings will be different. Good luck! Chris [email protected]
Feb 28, 2012 | Sony Grand WEGA KDF-50WE655 50" Rear...
Arcsoft Connect Daemon has stopped working
Hi Chris!
Thanks for your help. You're last suggestion worked like a charm and I've been annoyed by this error message for a couple of years at least!!
Thanks again!
Michelle
Apr 14, 2011 | Arcsoft Computers & Internet
Nokia CK-7W car kit won't stay switched off when ignition is off!
Main control box could be anywhere behind the dash, try under the glovebox or under the radio. If you have a mute harness to make the sound come through the speakers, this could also be the problem as is sound like you have 12v constantly on the blue wire.
Nov 24, 2009 | Nokia Ck - 7w Bluetooth Wireless Hands -...
Dear fixya,i have a sony ericson 850i.it will not charge.it keeps coming up with the message "charging error"charging stopped.your help please.kind regards chris
Well there could be 3 things wrong
1 is your charger is faulty
2.battery is faulty or 3 something else.
I would return the phone to your dealer,at least he can check battery and another charger.
Chris i hope i`ve helped
Nov 22, 2009 | Sony Ericsson K850i Mobile Phone
How do i make the weather degree sign ? ? ?
In windows, click Start>Programmes>Accessories>System Tools>Character Map. Here you will find every symbol and you can copy this to the clipboard for pasting into any application you require.
Regards
Chris
Nov 06, 2009 | Gateway 2520915 Keyboard
Measuring Tools & Sensors Logo
320 people viewed this question
Top Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
