After some start up time it will eventually (after 10-15 minutes) keep running. The sounds (start-up sounds; on/off) is coming from the upper part of the refrigerator on the wall that connects to the freezer.
Hi David, thank you for your inquiry. I understand that your Frigidaire Refrigerator is cycling on and off more than you expected. Todays newer refrigerator's have to meet Dept of Energy (DOE) specifications for energy savings. Typically the fan and compressor runs to get the fresh food temp down to 34*, the compressor shuts off and the fan runs for thirty more minutes and shuts down. The fan will repeatedly cycle on and off to keep the temp down as close to 34*. Once the temp in the fresh food hits 40* for more than two minutes the compressor cycles back on again. This will cause the temps in the fresh food to dwell between 35-40 and in the freezer section between 8-15. Hope this helps! -JK
SOURCE: Amana bottom freezer/ refrigerator
Geezer, sounds like a defrost issue. I usually find the bi-metal to be the culprit on this model. Check out the pic. You will have to remove the back panel in the freezer and defrost the evaporator. Remove the ice maker if there is one. The back cover has 4 quarter inch screws. remove those. The air vent has 2 plastic clips one each side and one on the bottom, push in and pull the grill off. The thermistor cover has a slot for a flat blade screw driver,push in and pull the cover off. The thermistor will now slide behind the back panel. Check the bi-metal for buldging. As long as the evaporator fan is working, it's probably a defrost problem.
SOURCE: clicking sound - not cooling
The problem is most likely the condenser fan motor at the back-side/bottom/right of the unit. If this fan is not turning, unplug the connector to this fan (inside the protective cover on the wires near the fan)... if the clicking stops, then this fan needs to be replaced.
What is happening is that this fan has failed but continues to draw a heavy load from the circuit board... It draws enough power from the circuit board to drop the voltage on the circuit board to 5-6 volts and the relays on the board open up and disconnect the power to the fan. The the voltage jumps back up to 12-13 volts and the relays turn back on causing the voltage to drop again and the relays to open.... ON....OFF...ON...OFF..... thus the clicking!
The exact part number for this fan may vary depending on the model and serial number of your unit... My model is GBS22K-BRBBB and the fan part is WR84X10055 and should cost $60-$70 though I have seen it being sold for as much as$130.
SOURCE: Freezer not freezing, refrigerator warm, hear clicking sound
The overload/relay on the compressor is shorted . This is the piece with 2 or 3 wires connected to it , mounted on the compressor . The part # you need is 8201786 . Complete mounting instructions , come with this kit . Easily replaceable .
SOURCE: Whirlpool refrigerator side by side freezer won't freeze
your over-load/contactor is defective, un plug it from compressor and shake it if it rattles its bad
