Question about Protron PD-800 DVD Player
NO SOUND MY PROTRON DVD PLAYER IS ONE YEAR OLD.EVER SINCE I STARTED USING IT, I HAVE HAD TO USE THE LASER DISC LENS CLEANER CD AFTER ABOUT ONLY 3 USES BECAUSE NO SOUND IS HEARD-ONLY VIDEO. NOW, EVEN THE DISC CLEANER CD WILL NOT RESOLVE THE PROBLEM. THE UNIT IS REGISTERED WITH PROTRON. PLEASE ADVISE WHAT I SHOULOD DO.PATRICIA MEYER
Posted by TONYCACI on
  • TONYCACI Nov 18, 2007
    THE MODEL # IS PD-007, NOT PD-800. CAN I FIX THE ALIGNMENT MYSELF. THE REPAIR SHOP WILL COST AS MUCH OR M,ORE THAN A NEW UNIT.
Lyle Siemens
  • 328 Answers
I would have to think that the laser lens unit is out of alignment. That is why it works after cleaning it for a short time. Bringing it to your local electronic repair shop should fix this problem at minimal cost to you. You did say it is one year old, if just over, then there is no warranty. You dont have to bring it to a high-end place for this simple repair because they tend to cost too much.
Posted on Nov 18, 2007
  • Lyle Siemens
    Lyle Siemens Nov 18, 2007
    You can try to physically move the lens mechanism yourself slightly and gently and try it every time. Chances are though, it might not work that way. A large buildup of dust or grease can prevent it from moving properly too and should be looked at first. The laser mechanism is a presicion instrument and not much can be done at home for it. There are repair shops that are much cheaper than others and do the same quality repair. There is a chance that the reader has to be replaced but trying the other solutions first could save you money.
Anonymous
  • 100 Answers
Seems that your disc/cd reader which is in the DVD Player itself is damaged, try to move it a bit with your finger, blow some air out of your mouth at it and clean it again. If that didnt work, take it to protron shop and change the reader.
I have an elderly JVC dvd player; the videos appeared broken up, even the sound was in- consistant. i changed the batteries in the remote and tried several different DVDs, but no improvement.
Try either using a DVD/CD laser cleaning disc or if you are able to, open the case and manually clean the laser lens with a cotton swab. It may only be a dusty/dirty laser. If you choose to open up the DVD player, give all the internals a dust off with a clean household paint brush and a vacuum cleaner (*use care on both the laser lens and internals of the player to avoid damaging it). If this does not solve the corrupted image and audio, the laser may be at the end of it's life and the unit will need replacing.
Here's an example of a DVD/CD player laser cleaning disc so you know what to look for -
Cleaning DVD CD Disc Lens Cleaner Kit WII XBOX PS4 Disc Player Dust Dirt...
Oct 11, 2018 | JVC Televison & Video
I put a dvd in and it says it is loading and then it says no disc found even though it is in the dvd player. I have tried several different dvd's.
Unfortunately , Some DVD players cant read some DVD s and
then it gives either "loading" or " no disc"..reading on the display...
it generally happens when you want to play "A copied DVD/CD " taken from somewhere else..
Just to make sure that such DVD is ok ,you can try to run them on your laptop.If the disc itself has problem, laptop does not read either..
Since you h
ave not stated,if it is an old player pls Clean your DVD player's LASER lens anyway .. A clean DVD player Lens ensures that your DVD disc would be read properly. Unfortunately, your DVD player's Lens accumulate as much dust and lint as the other parts of the DVD player. There are many available DVD lens cleaner kits that you can purchase and use to clean your DVD player.
YOUR DVD disc itself should be clean and finger prints free as well....
Here are three suggested DVD Lens Cleaner that should do the job of cleaning your DVD Player's lens.
Memorex Laser Lens Cleaner for DVD - This cleaner contains six soft brushes that gently remove dust, dirt and other airborne contaminants from your DVD player's lens. (Price: $6.09)
Maxell DVD-LC DVD Lens Cleaner - This DVD Lens cleaner features the "Thunderon Brush System" and include tests for audio performance including Dolby 5.1 surround sound. It also features an interactive on-screen instructions in 8 languages including system set-up. (Price: $10.81)
Allsop 23321 Carbon-Edge DVD and CD-Drive Cleaner - This DVD Lens Cleaner features an 8 brush carbon-system with carbon edge that removes static build-up from your DVD Players. It prevents skipping and also improves the sound and picture output of your DVD Player. ($13.11)
Hope this helps! Take care and please Remember to rate/vote and
give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Jul 26, 2011 | Proscan 32LB30QD 32 in. LCD TV
My Sony DVD player will accept the DVD but fail to load and play the DVD?
Unfortunately , Some DVD players ,especially brand ones cant read some DVD s and
Since you h
ave not stated,if it is an old player pls Clean your DVD player's LASER lens .. A clean DVD player Lens ensures that your DVD disc would be read properly. Unfortunately, your DVD player's Lens accumulate as much dust and lint as the other parts of the DVD player. There are many available DVD lens cleaner kits that you can purchase and use to clean your DVD player.
Thanks
Jul 25, 2011 | Sony RDR-VX500 DVD Recorder/VCR
After inserting dvd in player it reads no disc
Just in case,quick remedy ,
if this remedy does not help and if your set has still under warranty ,consult to service they may replace the LASER Reader EYE...most of the time Laser Eye malfunctions and does this..
if it is not under warranty ,never ,never have someone repaired it..go buy a new one,It will be cheaper.. ...
Hope this helps! Take care and please Remember to rate/vote and give me
Thanks
Jul 21, 2011 | Daewoo DV-6T834 DVD Player/VCR
Boss Audio System Model #BV8966B - will not play DVD or CD's anymore & keeps saying "No Disc"
then it shows either "loading" or " no disc"..
Some DVD players are fine at the beginning but after some time later,it begins to have some problems as you have..This is mainly due to LASER eye problems..
Thanks
Jul 11, 2011 | BOSS AUDIO SYSTEMS BV8966B Car Video...
How do you use a NEXXTECH Laser Lens Cleaner?
The NexxTech Laser Lens Cleaner uses six super-soft brushes to ensure thorough and reliable cleaning, without harming the delicate optical components of your disks. Enjoy your DVDs more and improve your music archive by cleaning your optics in your CD or DVD ROM. The easy-to-use audio instructions walk you through the cleaning process from start to finish. This laser lens cleaner process will prolong the life of your disc player, improve visual clarity and sound quality. Features
  • Works on CD, DVD, Blu-ray - all optical drives
  • The six brush system cleans off the entire laser lens
  • Will not damage sensitive optical components
  • Includes easy-to-use audio instructions
How to Clean the Laser Pickup Lens on your DVD Player X missing_author_image.png eHow Electronics Editor This article was created by a professional writer and edited by experienced copy editors, both qualified members of the Demand Media Studios community. All articles go through an editorial process that includes subject matter guidelines, plagiarism review, fact-checking, and other steps in an effort to provide reliable information. By an eHow Contributor
Is your DVD player malfunctioning? If you're getting a no-disc error, you may need to clean the DVD player's laser pickup. The laser pickup is what reads DVD's and allows you to view them on your TV. If you need to clean the laser pickup lens on a DVD player, follow these simple steps.
Difficulty: Moderate Instructions things you'll need:
  • Isopropyl alcohol
  • DVD lens cleaner
    • 1 Make sure the laser pickup lens is actually the problem. There are a wide variety of reasons that a DVD player might not read a disc efficiently. The disc could be scratched or dirty, for example. Test the DVD player with a disc that you know works before trying to clean the lens.
    • 2 Purchase or borrow a lens cleaner disc and try it first. You can find these things really cheap at any large department store. They usually get the job done well. However, you may need to clean the lens manually if the store-bought cleaner fails.
    • 3 Remove the outer casing of the DVD player. Remove the screws that mount the top casing onto the bottom of the DVD player and slide the top casing off. This will expose the DVD deck, which houses the laser pickup lens.
    • 4 Find the lens. The lens will be glass and under the DVD clamp. The lens will probably have a blue tint to it. If you are having trouble finding the lens, you could shine a light on the components and watch for the reflection.
    • 5 Use a cotton swab and some isopropyl alcohol to gently wipe the lens. Just a quick scrub will do. Dry the laser pickup lens with the other end of the swab.
    • 6 Give the lens a few seconds to dry and replace the covering of the DVD player. Test the efficiency of the player. If necessary, repeat the process.
May 05, 2011 | Televison & Video
Will not play blu-ray movie Date Night. I have tried 3 movies
Will it play other movies? If so, your "Date Night" disc is almost certianly defective. Try it somewhere else
If not, the player has a problem. Try cleaning the laser with a laser lens cleaner (something like this: http://www.buy.com/prod/memorex-cd-dvd-laser-lens-cleaner-6-brush-drive-cleaner-memorex-cd-dvd/q/sellerid/11408470/loc/101/10340589.html) Blu-Ray is more sensitive to dust because of the thinner laser it uses. If that doesn't work, more likely than not the laser has died or requires adjustment.
[Just for the record, I had an early DVD player (I forgot the brand name) that would play every movie fine except "Stuart Little". This movie worked fine on other players, but not in mine. It would enter the menu>special features all by itself. Let us hope you are not experiencing a similar case.]
Sep 27, 2010 | LG BD390 Blu-Ray Player
DVD player will not play disc.
If you are loading a store bought DVD and that it what it say's. The transport needs to be replaced. roughly 150-200. If you are loading "burned" DVD's the format may be wrong and the unit cannot read it. Best suggestion I can give you is to first buy a "Laser Lens Cleaner" on that uses fluid. Any electronics store sells them for 15-20. Run it thru the unit a couple of times then try a clean, store bought DVD. If it plays, problem solved. With your DVD's, if you have any liquid car polish like mother's or meguiars, put a couple drops on the disc and spread around with your finger, let it set a couple then buff off with a microfiber towel. This works wonders for old scratched cd's and dvd's and helps protect new ones from getting scratched. As for the Lens cleaner, run it thru every product you have that uses discs 3 or 4 times a year, it's the best preventative maintance and only maintanance you can do on a CD player DVD or PC. Hope this helps
Jun 24, 2009 | Delphi 10.2" FLIP DOWN MNTR/DVD...
Protron says wrong disc
there are so many reasons to that legend,dirty laser lens,capacitor dried on the electric feed board,flat connector between the laser lens and the board,bad motor spin disc.good luck
Mar 19, 2009 | Protron PD-007 DVD Player
Portable DVD player Scratches the disc
one of the most common problems with a cd or dvd player when it sctatchs the disc is thats ikts been abused. The turntable or lens is out of alighnment and scratching the disc.
Mar 28, 2006 | Protron PD-758LP
Protron PD-800 DVD Player Logo
43 people viewed this question
Top Protron Televison & Video Experts
Ekse
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
