Question about General Electric Washing Machines
How do I clean the basket of my front door General Electric washing machine
How do I clean the basket of my 2007 front door General Electric washing machine
5 Related Answers
Anonymous
  • 249 Answers
SOURCE: Whirlpool 1A-1B Washing Machine door leak
solution fit new door seal,its leaking where door seal meets glass
Posted on Jun 20, 2008
Anonymous
SOURCE: Frigidaire Affinity ATF7000ESI - won't spin
I just had this problem with my Frigidaire Affinity ATF7000EE0.
When the machine seems to work fine (as it will wash but just won't kick into a spin cycle) it is most likely the door lock/switch assembly. In addition to the actual door lock solenoid and door closed switch, the assembly contains a secondary lock in the form of a wax motor and an auxiliary switch. This wax motor and switch activates during the spin cycle. When the wax motor goes bad the secondary lock does not activate therefore the spin cycle switch does not activate, which in turn disables the spin cycle. Even though you can hear your door lock kick in and the door is locked it is most likely the secondary lock in this switch assembly. Start by replacing it first.
Unplug the washer unless you want to get shocked! Take out the two screws at the back of the washer that holds on the washer top and remove the top by sliding towards the back of the machine and lift up. You can go to the front of the machine and reach down inside to the door lock while removing the two screws that hold it in from the outside front of the machine. Once the lock is removed there should be enough wire slack to get the lock up above the tub before you go and try to unplug any connections. Make sure and make notes as to where your connections go on the switch. Simply unplug the old switch and plug your new lock assembly in, remount it, and put the top back on. You should be good to go.
One note, don't panic if you select spin cycle and it doesn't start spinning immediately. Wax motors actuate very slow and smoothly. It could take up to a minute for the lock and switch mechanism to get into place before the spin will start.
Have a great day!
Posted on Nov 14, 2008
shaher353
SOURCE: Ariston "Margarita 2000" Model AL129X [front load washing machine] - Clean sludge from door seal.
Ariston "Margarita 2000 cpu map photo
Posted on Nov 20, 2009
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Front loader washing machine stinks really bad
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
tstoleson
tstoleson
SOURCE: Washing machine doors
Electrolux has a reversible door for both front load washer and dryer. Just found that out at HHGregg because we need to put our washer to the right of the dryer, and none of the other makes will allow the washer door swing to be switched.
Posted on Jan 06, 2013
Leaking
is the door seal damaged
if no
clean the scale from the glass
where the door seal sits on the glass??
1helpful
Not spinning
If its a front load, do you know about the clean out drain behind the lower front panel? Get ready with a bucket to catch all the water, lint, money and bobby pins coming at you. Under the door there is a panel, you will need a screw driver to get it off. Under that panel is a knob to unscrew a pull out.
I have a code door locked in my WCVH6800J2WW
Poss able sensor problem. When the sensors go it stays locked indicating water inside, even though it is empty.
Basket not spinning
Check the door switch to make sure that it is ok. The motor in this is direct drive so it could be the controller.
2answers
I have a GE Front Load Washing Machine, Model Number WBVH5300. When I turn it on to any cycle, the door locks, the basket turns to balance the load, the door unlocks, relocks and begins to drain. There...
Hello & Welcome to FixYa
If the drain hose is positioned correctly and the door lock assembly is fine then the problem is either the drain pump that is bad and needs replacement or the drain pump relay on the control board is bad and replacing the board will be recommended repair. Please get back to me if you have any other questions.
Kevin
2helpful
3answers
There is a musty oder coming from inside washing machine.
Dump in a gallon of white vinegar, fill with water, highest setting, after it goes through that setting, turn it off and let it set in the washer for about 30 minutes (use hot water).
Then put it on another wash cycle and then go to the rinse and spin. This should remove the order, and you should leave the door open when not in use.
Good Luck
My 2007 GE Adore Washing Machine has the red button permanently on "Lock" and the machine is not doing anything. Help!!!!!
it says lock because the machine still has water in it lower your waste pipe let water flow out door will open then unblock or replace pump
Washing Machines Logo
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Paul Bade
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
