Televison & Video Logo
Lovely Deals Posted on Oct 27, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to fix my aoc 24" flat screen tfv if it's showing negative screen?
Electro Med Services
Level 3:
  • AOC Master 6,694 Answers
  • Posted on Oct 27, 2015
AOC Master
Level 3:
Answers
6694
Questions
Helped
1870201
Points
21433
Your tv have problem with the LCD panel drive circuit normally know as timing control board (t con). Normally bellow 32 inch tvs the t con board is integrated to the panel itself. so you have to go for now lcd panel for your tv.
www.electro-medical.blogspot.com
How do I fix my 24" aoc tv if it's negative screen
Check and replace its T'Con board. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
My aoc l24h898 lcd tv led light turns blue but then turns red in seconds
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
How do you reset an AOC tv ?
Try this:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
AOC L24H898 has audio, no video
This sounds like a power supply problem that causes the high voltage power supply to shut down when it warms up. A repair shop may be able to fix this.
Service mode aoc lcd tv
This sounds like a common problem on these TVs. Try a factory reset:
3. *A small screen should appear in the top left part of the screen.
If this still does not work, perform steps 1-3, but when you get to step 4, select "EEPROM Init". Then steps 5 and 6 to power it off and back on.
Envision flat screen tv has 5 channels that don't play volume but show pic
Check the volute settigs to these channles. Check whether system set is compactable with input.
39helpful
3answers
Buttons locked on AOC 24'
On the tv press and hold the + and - volume control buttons and the buttons should unlock.
5helpful
2answers
INPUT NOT SUPPORTED
Start your Windows in Safe Mode (pressing F8) during boot process and adjust your Display Settings to a lower resolution.... say 1024 x 768. Once fixed, you can play around again increasing the resolution a notch at a time. Fix ya!
Top AOC Televison & Video Experts
Arnie Burke
Arnie Burke
Are you an AOC Televison and Video Expert? Answer questions, earn points and help others
