Question about Sharp R-930AK Convection/Microwave Oven
Turntable turns, lights work, but no heat oouput
Posted by thomas hart on
GE spacemaker XL1400
what problem do you have mention ? attached is there a list please indicate. God bless you
    No Lights or Power, Unit seems Dead The voltage to the unit is good.Lights come on, but can not program unit, Touchpad dead
    Microwave Runs, but no Heat Turntable rotates, acts like it is heating but doesn't. This is the big one, many possibilities.
    Microwave Runs, Heats, but turntable does not move
    Microwave is arcing
    Microwave Vent Hood is not working Over The Range(OTR) Models.
    Microwave Stove Light not Working OTR models, light bulbs good.
    Microwave overheats and keeps turning off
Oct 01, 2012 | Microwave Ovens
My spacemaker 2.0 pvm2070dmww microwave is not heating and the turntable is not turning everything else is working fine.
The problem is more than likely a bad door switch, a digital meter is the best option for testing to find the defective one. If you have one post back for instructions or have serviceman repair it.
Jul 04, 2012 | GE Profile Spacemaker Over-the-Range...
My JVM1653 stopped cooking, The turntable turns
your magnetron might be out. its what heats
Feb 13, 2010 | GE JVM1653 Microwave Oven
Microwave will not heat food. punch in heating time, press start and nothing happens
HI. your control board has failed. you will need to replace the control board asap if possible.
May 30, 2009 | Panasonic Microwave Ovens
Bulb & turntable
Yes the microwave is safe to use, without the turntable working.
May 03, 2009 | Microwave Ovens
Turntable will not turn
If everything works, light and micro heating.. then I have 4 possibles for you to check... 1st make sure you don't have a button that allow you to turn the turntable on/off... 2nd take the glass table out and check the center plastic spinner(pull it out) and see if its broken. 3rd your turntable motor is bad, and 4th the relay for your turntable on control board is bad... helpfully that will do it for ya.. good luck.. mike
Dec 20, 2008 | Kenmore 62622 Microwave Oven
Dacor dcm24s.light, fan, and control panel work but turntable and heat do not
Most likely the bottom door switch. Dacor units are built by Sharp and that switch is a very common problem. You'd either need to check the switch with an ohm meter or remove the cover of the switch to see if it's burned inside.
Oct 20, 2008 | Sharp R-930AK Convection/Microwave Oven
Microwave oven does not heat anything. Clock, turntable, lights work. I turned the turntable off while the oven was cooking--heard a noise, now it doesn't heat anything.
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
Jul 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Nov 03, 2007 | Roper MHE14XKB Microwave Oven
Sharp R-930AK Convection/Microwave Oven Logo
Top Sharp Microwave Ovens Experts
Michael Thomas
Michael Thomas
Gerry Harvey
Gerry Harvey
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
