I had the LC code flashing on my Samsung dishwasher and my mom also had the same problem with her Kenmore dishwasher! We tried everything everyone has posted and nothing worked!! Turns out it was an easy fix! Just add jet dry to the jet dry compartment on the inside panel of the door to the dishwasher and it worked!! No more LC code and the dishwasher now works fine!! I thought adding jet dry was an option?? Apparently it is a requirement with these new dishwashers!!
this sounds like the door alarm- it occurs after the door is open (or the switch has failed) for more than 2 minutes. Remember that both doors have one and also turn on/ off the lights which may or may not be tied together.
1. Disconnected the power cord from back of printer. 2. Open the Rear Access Door. 3. check if there is any paper piece stuck in rollers. 4. Clean the rollers using link free cloth ( wipe rollers in same way the paper is rolled [ wipe upwards ) 5. Close the rear access door 6. Open the front access door 7. Check for any paper stuck in carriage rod 8. Close the front access door.
Please remove all the paper's from paper try and re-stack the tray, make sure the papers are free and does not has moisture. Please the paper in tray
9. Connect the power cord back and power on the printer.
System error C00F0401 This error message can occur if the
all-in-one has been stored incorrectly.
Unplug the power cord
to the all-in-one. Open the rear access door of the all-in-one.
Rotate the paper feed rollers in an upward direction. Reinstall
the rear access door. Reconnect the power cord.
If the
problem reoccurs, contact HP for assistance. and
Performing a Partial Reset of the All-in-Onesolves it go to this link http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&lang=en&os=219&product=60259&docname=c00060793
