Question about Sharp 70" LC-70LE757U AQUOS Full HD Smart LED 3D TV
TV will not come on, white light center bottom of tv flashes twice then 5 times
Would like to order part and try to fix myself
    Top Expert:
  • Sharp Master
  • 76,823 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Posted on Oct 27, 2015
3 Related Answers
Anonymous
  • 9 Answers
SOURCE: power light flashes twice,then opc flashes once then power again
In all the time that you have had the tv have you applied 2 firmware updates that some of the tv's need to avoid other known issues with the lcd in the future. These firmware updates are for the main cpu PH1UU112 and the monitor MD1UA104. I don't know if this is the case for you but it worked for me. Call Sharp at 1-800-237-4277.
Posted on Oct 07, 2009
bshldn
Loretta Northcutt
  • 736 Answers
SOURCE: TV will not turn on. There are two lights in front
Sounds like your screen is broken or has been impacted. Force the television on by doing this: Unplug it and on the side of the television where the panel buttons are hold down the ch- and vol+ buttons. Then plug in the television while still holding them down. The television should come on and you see the cracks. Unfortunately it can't be repaired.
If it isn't ch- and vol + then try ch + and vol -.
Posted on Feb 05, 2011
Chi Chu
  • 8457 Answers
SOURCE: My Sharp Aquos TV went off whilst we were watching it and won't come back on. The red power light flashes twice per second and the green OCD light flashes three times every second. Is there a re
Tries tv unplug replug the tv back about an hour later,might resetting the tv back factory setting and should work again.Still have the problems,the main board it is shorted and dead require changing.The main board that board were the incoming broadcasting signal wire plug into it.U have some basic machanic skills like take things a parts and putting it back together again.Should have no problems change this board at all..Tried websites like Shopjimmy.com,eBay.com to buy a refurbish main board for the replacement.
Posted on Feb 24, 2013
Program code for Directtv Universal remote.
You can see an easy step-by-step guide to programming your remote right on your TV screen:
sm_cl_blu__number1_icon.pngPress MENU on your remote control sm_cl_blu__number2_icon.pngSelect Settings & Help sm_cl_blu__number3_icon.pngSelect Settings sm_cl_blu__number4_icon.pngSelect Remote Control sm_cl_blu__number5_icon.pngSelect Program Remote and follow the on-screen prompts img_remote_control_tv_sol1.jpg You can also use the manual method below: sm_cl_blu__number1_icon.pngMake sure your TV and your receiver are both on. sm_cl_blu__number2_icon.pngUse this tool to look up the 5-digit code for your TV. There could be more than one code for your brand of TV. sm_cl_blu__number3_icon.pngSlide the MODE switch on your remote control to the TV position. sm_cl_blu__number4_icon.pngPress and hold the MUTE and SELECT buttons at the same time until the green light at the top of your remote flashes twice, then release both buttons. sm_cl_blu__number5_icon.pngUsing the number buttons, enter the 5 digit code for your brand of TV. The green light under the TV should flash twice. sm_cl_blu__number6_icon.pngAim the remote at your TV and press the VOLUME UP button. If the volume doesn't increase, repeat Steps 3-5, trying a different 5-digit code for your TV. If your remote control fails to program using all available codes, try scanning for additional codes. If one of the codes worked, proceed to the next step. sm_cl_blu__number7_icon.pngPress and hold MUTE and SELECT buttons until the green light at the top of your remote control flashes twice. sm_cl_blu__number8_icon.pngEnter 9-6-0 using the keypad on the remote control. The green light should flash twice again. sm_cl_blu__number9_icon.pngSlide the MODE switch on your remote control to the DIRECTV position. img_remote_control_tv_sol2.jpg Follow these steps to scan for additional TV codes using your DIRECTV remote: sm_cl_blu__number1_icon.pngSlide the MODE switch on your remote control all the way to the right to the TV position. sm_cl_blu__number2_icon.pngPress and hold the MUTE and SELECT buttons at the same time until the green light at the top of your remote flashes twice, then release both buttons. sm_cl_blu__number3_icon.pngUsing the number buttons, enter 9-9-1. The green light on your remote should flash twice. sm_cl_blu__number4_icon.pngAim the remote at your TV and press CHAN/PAGE UP button. Tap the CHAN/PAGE UP button repeatedly until the TV powers off. sm_cl_blu__number5_icon.pngWhen the TV powers off, press and release the SELECT button. Note: If the green light flashes three times before your TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, but your TV may not be compatible with our remote control.
6helpful
2answers
Trying to program a direct tv remote to work with my 46" lcd, Vizio tv. Have tried the codes provided, but they don't show when I type them...not sure if actually being entered. Or, maybe have...
1 Vizio tv.code 0864 OR 10885 OR 11756OR 10178
Unable to Find Correct Code
If you were unable to find the code for your brand of TV or component, you can try a code search. This process may take up to 30 minutes.
1. Turn on the TV or component. Insert a tape or disk if applicable.
2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
4. Enter 9-9-1 followed by one of the following four digits:
Satellite - 0
TV - 1
VCR/DVD - 2
Stereo Receiver/Stereo Amplifier - 3
5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
6. Point the remote at the TV or component and press CHAN+. Repeatedly press CHAN+ until the TV or component turns off.
NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7. Use the CHAN- key to step back a code.
8. When the TV or component turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the remote that came with your TV or component.
Verifying the Codes
Once you have set up the DIRECTV Universal Remote Control using the above steps, use the following instructions to find out the 5-digit code to which your component responded:
1. Slide the MODE switch to the appropriate position.
2. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
3. Enter 9-9-0. (The green light under the selected switch position flashes twice.)
4. To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down.
5. Repeat step 4 four more times for the remaining digits; i.e., press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.\
Depending on how you set up your remote, the VOL and MUTE may control the volume only on your TV, regardless of the position of the MODE switch. This remote can be set up so that the VOL and MUTE keys work only with the component selected by the MODE switch. To enable this feature, perform the following steps:
1. Press and hold the MUTE and SELECT keys until the green light under the DIRECTV position flashes twice, then release both keys.
2. Using the number keys, enter 9-9-3. (The green light will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light flashes 4 times.)
Now the VOL and MUTE keys will work only for the component selected by the MODE switch position.
To Lock Volume to AV1, AV2 or TV
1. Slide the MODE switch to the AV1, AV2 or TV position to lock the volume.
2. Press and hold the MUTE and SELECT keys until the green light under the selected switch flashes twice and release both keys.
3. Using the number keys, enter 9-9-3. (The green light flashes twice.)
4. Press and release the SELECT key. (The green light flashes twice.)
I am trying to program my "Direct TV" remote to my Samsung LCD TV Series 5 and can not find the 5 digit code needed to do so.
If you have a DIRECTV white remote, press "menu" then "settings," "setup," "remote", and follow the on-screen instructions.
If using a gray or black remote,
  • Make sure your TV is turned on.
  • Slide the mode switch at top of remote to "TV".
  • Press and hold the MUTE button. This is located above the number 1 button.
  • While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
  • Then enter 9911, the green light on remote should flash twice.
  • Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
  • When the TV powers off, press and release the SELECT button.
  • 2helpful
    2answers
    Sony KV-28DX30U TV - No picture, only sound.
    5 times flash code shows problem with AKB (white balance of CRT)
    Please adjust RGB gain and screen volt of this TV.
    1helpful
    Need code for Directv remote for 26LG Flat Screen TV
    Program TV Code
    1. Turn on the TV.
    2. Locate the 5-digit code for your TV.
    3. Slide the MODE switch to the TV position.
    4. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
    5. Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
    6. Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
    7. Slide the MODE switch to the DIRECTV position. Press TV POWER. Your TV should turn on.
    Program DVD, VCR, Stereo Receiver, and Stereo Amplifier Code
    The AV1 and AV2 switch positions can be setup to control a VCR, DVD, STEREO, second DIRECTV Receiver or second
    1. Turn on the component you wish to control (e.g. your DVD Player).
    2. Locate the 5-digit code for your component.
    3. Slide the MODE switch to the AV1 (or AV2) position.
    4. Press and hold the MUTE and SELECT keys at the same time until the green light under AV1 (or AV2) flashes twice, then release both keys.
    5. Using the NUMBER keys, enter the 5-digit code for the brand of component being set up. If performed correctly, the green light under the selected position flashes twice.
    6. Aim the remote at your component and press the PWR key once. The component should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
    7. Repeat steps 1 through 6 to set up a new component under AV2 (or AV1).
    Satellite - 0
    TV - 1
    VCR/DVD - 2
    Verifying the Codes
    You just dropped me without answering my question or really even trying
    I can see you are frustrated so I'll see if I can help. Here are the Akai TV codes:
    10812, 10702, 10030, 10672, 10060
    As you can see, they are 5-digits for the direct remote, not 4.
    This should help!
    Program TV Code
    1. Turn on the TV.
    Satellite - 0
    TV - 1
    VCR/DVD - 2
    Verifying the Codes
    Hope this helps
    Happy New Year!
    Chris (ziraffa)
    3answers
    Directv remote
    1) Use 2 new AA batteries in RC32 remote control;
    2) Slide mode switch to "TV";
    3) Press and hold the MUTE and SELECT keys at the same
    4) Enter 9-9-1-1.
    5) Press PWR button on TV.
    6) Point the remote at the TV and press CHAN+. Repeatedly press CHAN+ until the TV turns off. Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
    7) Use the CHAN- key to step back a code.
    8) When the TV turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key. If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the TV remote control.
    9) To verify the code, slide the MODE switch to the appropriate position.
    10) Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
    11) Enter 9-9-0. (The green light under the selected
    12) To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down in the TV owner manual.
    13) Press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.
    To control TV volume from Directv RC32:
    flashes 4 times.)
    2answers
    Sharp tv 2004 model
    Program TV Code
    1. Turn on the TV.
    Satellite - 0
    TV - 1
    VCR/DVD - 2
    Verifying the Codes
    Tv repair
    My Tv was doing the same thing, and I had to unplug the set in order to get rid of the blinking light. And what i did was to turn the power on and as soon as i saw the picture i turned it off, I did this 5 times and on the 6th time I let it power and tv stayed on, however something did happend to my set, i found that my convergence was wacky. Tried to center convergence but i could not center the blue. Turns out, i think the problem is with my Convergence ICs that went bad. I can still watch tv but the Image has blue color shadows and the picture slightly bows inwards from top and bottom. To sum this up, i will need to replace 2 ICs, IC C5AA00000203, and this should fix my problem. I will do this repair myself, each part is about $41..
    Let me know what happened to your problem.
    Thanks
    Tony
    Color variation and blinking red light on bottom of tv
    The light flashing 5 times is normal at turn on as the set is monitoring current drain on the pictures tube cathodes. Any speakers near the set that have un-shielded magnets could possibly cause color issues.
    Sharp 70" LC-70LE757U AQUOS Full HD Smart LED 3D TV Logo
    Top Sharp Televison & Video Experts
    Ekse
    Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
